Calculating Radius of Driven Gear from Given Info
  • Thread starter Thread starter deuel18
    Gear Radius
3 replies · 2K views
deuel18
I'm currently designing two gears meshed together. I know that the pinion gear must travel at 85 degrees from 0 while the driven gear must travel at 120 degrees from 0 - both gears must travel and stop at the same time. In addition, I do know that the pinion gear must be 1 inche in diameter. Is there a way, based on the information given, to calculate the radius of the driven gear? Thank you very much.
So for every 85 degrees the pinion rotates the other gear rotates 120 degrees.
We could also say if the pinion rotates at 85 rpm the other rotates at 120 rpm, can you work out the gear ratio now? and use that ratio to find the driven gears diameter?
