Calculating Spatial Separation Using Lorentz Transforms: Homework Solution
  • Thread starter Thread starter Mugen Prospec
    Separation
Mugen Prospec
Two events occur at the same place in a certain inertial frame and are separated by a time interval of 4 seconds. What is the spatial separation between these two events in an inertial frame in which the events are separated by a time interval of 6 seconds?
Lorentz Transforms
I really have no idea where to start. I know its not that hard I am just drawing a blank
Lorentz Transforms
Hint: What quantity involving both time and position is invariant under Lorentz transforms?
I know the speed of light is invariant. The way I worked it was putting it through the Lorentz time transform solving for v. then put that v in the x Lorentz transform
Sure, c is Lorentz invariant, but it doesn't invole time or position, so that doesn't help. What about the spacetime interval \delta s^2?
Could you give me maybe a walk through on how to find that or even the problem. I am really at a loss, I missed a week of classes because i was sick.
I'm not here to teach a week of coursework. Read the section in your text that talks about spacetime intervals and then try the problem.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
