Calculating Speed of Mass Given Constant Power & Force
The discussion revolves around calculating the speed of an 8.00-kg mass subjected to a constant power of 45.0 W and an initial force of 5.00 N. The mass is initially moving in the direction of the force, and the problem involves understanding the relationship between power, force, and velocity over a time period of 4.00 seconds.
  • Participants explore the concept of power and its units, questioning how power relates to force and velocity. There is an attempt to clarify the role of integration in the problem, with some participants expressing uncertainty about their mathematical skills. Others discuss the implications of the force being constant only at the initial moment.
The discussion is active, with participants providing insights into the relationship between power and force. Some guidance has been offered regarding the understanding of power as a rate of energy transfer, and there is an ongoing exploration of how energy changes over time. Multiple interpretations of the problem are being considered, particularly regarding the changing force.
Participants note that the force is not constant throughout the duration of the problem, which may affect the calculations. There is also a mention of the need for additional information to fully resolve the problem.
Fluent
A constant direction force delivers a constant power of 45.0 W to an 8.00-kg mass which is
initially moving in the direction of the force. At t = 0 s, the force is 5.00 N.
Calculate the speed of the mass after 4.00 s.
I've tried to do several different things, however I believe you need to integrate. My intregration skills are really weak, so please don't assume I'll know what you're doing if you skip a lot of steps.
Thanks.
Welcome to PF.
You're in luck. You won't need to integrate.
But you will need to understand what power is.
Like what units is power expressed in?
Kg m^2/s^3
Few more points would be helpful.
Thanks
OK and how is power related to Force?
Power = Force times ...?
velocity.. however unfortunately the answer is not 9 m/s. The other information is needed to solve this.. as the force isn't the same throughout.. (it's 5.00 N only at t = 0 s)
You are jumping ahead a bit.
The 9 m/s is the speed at t=0 however.
Now think about what is a watt? A Joule/sec perhaps?
And how many seconds? So how many Joules were added to the energy of the mass? ...
And how many joules of energy did the mass have at t=0? And added together as Kinetic energy how fast does that mean the mass is going?
Ahh thanks a lot man.. appreciate it.
  • · Replies 20 ·
  • · Replies 17 ·
