Calculating Spring Constant of a Hanging Spring
6 replies · 2K views
teng125
A spring with length l = 8 cm hangs in
vertical direction somewhere close the Earth's surface. When a mass of m = 10 kg is attached
to the spring its rest-position is at y0 = 11 cm. (a) Determine the spring constant k.
i try to use F=-kx = mg where x=11cm - 8cm
therefore,i would like to know whether my steps are correct or i used the wrong formula
somebody pls help
part b) The
mass is pulled out of its rest-position by a distance Δy = 5 cm. What is the acceleration acting
on the mass in the moment of its release?
i got the answer of a=16.35m/s^2
am i right??
somebody pls help
You're in the right direction :) Remember that at the spring its rest position [tex]F_{gr.} = F_{spring} = C \cdot u[/tex] where C = spring constant.
So you need to solve: [tex]m \cdot g = C \cdot u[/tex] with u = distance of strecthing of the spring (3 cm)
foir b i would say that you use the second law of Newton: [tex]F_{res} = m \cdot a[/tex]
You are correct. (Except for that minus sign. Set the magnitude of the spring force equal to the magnitude of the weight.)
teng125 said:
part b) ...
am i right??
Looks OK to me. (But next time don't just give your answer; show how you got your answer. :wink: )
agrees with Doc Al :)
