Calculating stiffness from load and defletion
  • Thread starter Thread starter Jackcheasley
    Load Stiffness
3 replies · 7K views · last reply
Jackcheasley
ok i loaded a composite laminate beam across the centre of a 1.44meter span with 415N load. This deflected the beam to a distance of 0.05m (5cm).
Im having trouble calculating the stiffness from this.
The composite laminate is 5mm of wood in a glass fiber sandwich with both the top and bottom layer measuring 1mm thick making a total depth of 7mm. The beam has a base of 27cm.
some of the equations i have are:
s=415*1.44^3/48EI
or
D=Eskin/12*(0.07^3-0.05^3)+Ec*0.05^3/12
If anyone had any idea even if its different equations as I am unsure on these, any help is great
Thanks
What definition of stiffness would you be wanting to use? If it is force per unit displacement, then the experiment gives it you. If you want to compare that with a theoretical value, then maybe you should derive the formula for D from 1st principles, rather than trust it?
s=415*1.44^3/48EI
This equation is the theortical deflection of the beam at mid point if the beam is simply supported at each end. Since you may not know E or I for the composite material, your experiment gives you the deflection, as Pongo38 as noted. The stiffness of the beam under this loading and end condition is not the same as the deflection. The deflection has length units, and the stiffness has force/length units. Try using Hooke's law to calculate the equivalent stiffness of the beam loaded in this manner. you have the load and the deflection, what is the stiffness under this definition?
Awesome
Cheers guys Got it from hooks.
thanks
