Calculating table's legs positioning
  • Thread starter Thread starter ketamynx
This discussion focuses on the construction of a desk using an 80x30" MDF board that is 6/10" thick. It emphasizes the inadequacy of 1/2" MDF for load-bearing applications, highlighting its tendency to sag under weight. The recommended solution is to use 3/4" plywood for better structural integrity and to maintain a maximum span of 3 feet between supports. Alternatively, purchasing a pre-made top from Ikea is suggested for optimal durability.
  • Understanding of MDF and plywood materials
  • Knowledge of desk construction techniques
  • Familiarity with load-bearing principles in furniture design
  • Basic woodworking skills
  • Research the properties and applications of 3/4" plywood
  • Learn about load distribution in furniture design
  • Explore different leg types and their mounting techniques
  • Investigate Ikea's desk components and their specifications
This discussion is beneficial for DIY furniture builders, interior designers, and anyone interested in creating durable and functional desk solutions using MDF or plywood materials.
ketamynx
I have an MDF board (that corky stuff), 80x30" and 6/10" thick.
I want to make it a desk, so obviously I'm going to buy some legs from Ikea.
The leg is a regular tube, a socket and 5 screws.
Is there a way to calculate the safe distance to leave between the legs?
I mean I could just buy three legs and put them in a triangle shape but there's no guarantee of the board not breaking on heavier objects.
MDF can be moisture prone and is not meant for load bearing without lots of support. If you are using it as a desk it will sag over time with any weight. 1/2 MDF is not good desk material, it won't "break" like a solid board, but it's just not that strong.
Use 3/4" plywood and keep the span no longer than 3' between supports. Or just buy the ikea top, they usually sell them separately.
  • · Replies 42 ·
  • · Replies 67 ·
15K
21K
  • · Replies 16 ·
10K
