Calculating Tension in a Static System
  • Thread starter Thread starter thinkcentre12
    Statics Tension
The discussion revolves around calculating the tension in a static system, specifically focusing on vector directions and their implications in the context of a homework problem. Participants explore the relationships between tension vectors and their orientations.
  • Homework-related, Conceptual clarification, Technical explanation
  • One participant expresses confusion regarding the signs of the tension vector compared to the answer provided in the textbook.
  • Another participant clarifies that the tension vector points from point B towards point A, while the original participant had created a vector pointing from A to B.
  • There is a discussion about the difficulty of determining vector direction without visual aids, such as arrows.
  • A later reply mentions the presence of a weight acting downwards, indicating that the tension must act upwards to counteract this force.
Participants do not reach a consensus on the correct signs for the tension vector, and there is ongoing clarification about vector directions and their physical implications.
Participants express uncertainty about vector directionality and the impact of external forces, such as weight, on the tension calculations.
thinkcentre12
The answer in the back on the book shows 4.06i -7.61j + 5.07k. I do not understand why my signs are backwards.
I ended with -4.06i +7.61j - 5.07k
The tension involved is a vector that points from B towards A. You've created a vector rab that points from A to B.
ok thank you. Since i did not see an arrow i was not sure which direction to pick. How did you tell?
It's difficult to push with a cable :)
That is a good point. Thank you
Additionally, there is a weight pulling the boom downwards (or in the negative z-direction). In order to counteract this, the cable needs to pull it upwards (positive z-direction).
