Calculating the force provided by an opened compressed air tank
The force generated by a compressed air tank can be estimated using the formula F = P * A, where P is the pressure in pascals and A is the opening area in square meters. In this discussion, a tank with a pressure of 550 kPa and an opening area of 0.25 cm² was analyzed. While this method provides a maximum force estimate, it does not account for losses due to mass flow or kinetic energy conversion, which can result in a higher calculated force than the actual force experienced. For practical applications, especially in model car designs, using pressure times area is sufficient for rough estimates.
  • Understanding of basic physics concepts, specifically force and pressure.
  • Familiarity with unit conversions, particularly between kPa, pascals, and square meters.
  • Knowledge of conservation of momentum principles in fluid dynamics.
  • Basic understanding of thrust generation in propulsion systems.
  • Research the principles of conservation of momentum in fluid dynamics.
  • Learn about the effects of mass flow rate on thrust calculations.
  • Study the relationship between pressure, area, and force in pneumatic systems.
  • Explore practical applications of thrust calculations in model vehicles and rockets.
Engineers, hobbyists, and students involved in model vehicle design, fluid dynamics, or propulsion systems will benefit from this discussion.
AussieDave
Hey. Quick question.
If we have a compressed air tank of 550 kPa with a opening area of 0.25 cm^2, would the force provided just be P*A so it'd just be 550 * 0.25 (with appropriate conversions to metres and pascals etc). We are looking for the force that'd be provided to a model car that the tank (from a paintball gun) is attached to.
Or is it something a little bit more complicated than that. This isn't a homework question where we need an exact answer, we only need to estimate it.
I was having a similar problem actually. Any ideas?
If this is an estimate, then yes it's a perfectly acceptable method for calculating force. The force determined using this method will be a bit higher than actual.
Will you not also have a component due to mass flow?
Hi minger,
Good question. One can either analyze this assuming conservation of momentum OR assuming a pressure over an area. For example, consider a rocket. The total thrust is accurately determined using conservation of momentum alone - the pressure inside the combustion chamber is not additive, it is simply used to determine the flow and velocity.
Using just pressure times area is often done just to get a worst case (maximum force) value. Because that pressure has to be converted to kinetic energy (momentum), there are losses in this conversion for a simple orifice, so the force determined using pressure x area will always be higher than the force determined using conservation of momentum.
OK OK, basically yea it depends on where the CV is drawn. If its drawn right at the exit, then there is negligible pressure difference as the pressure has already been converted to velocity, whereas if it's across a larger portion, then velocities are small.
I recently did a problem with a nozzle. With a nozzle because there is a dP and change in velocity across the nozzle, both effects need to be considered.
I think this depends on your definition of accurate. For a small CO2 canister you can probably neglect the internal pressure but for something like a large diameter ducted fan, probably not.
Here's a good source to learn about thrust.
http://www.grc.nasa.gov/WWW/K-12/airplane/thrsteq.html
Hey fellas, thanks for your help.
I tried using conservation of momentum because I use that all the time in rocket equations. This is, however, just an estimate based on a gas tank that we'd buy online (we don't actually buy it...we just do the design) and there isn't any info on the mass flow rate.
I'll just use the Pressure x Area because it doesn't have to be a great estimate and the thng will never actually be tested for accuracy.
Thanks again.
  • · Replies 23 ·
11K
  • · Replies 20 ·
