Calculating the Minimum Height for a Steel "Boat" to Float
2 replies · 4K views · last reply
quick
The bottom of a steel "boat" is a 6.00 m x 9.00 m x 5.00 cm piece of steel(density of steel = 7900 kg/m^3) . The sides are made of 0.460 cm-thick steel.
what minimum height must the sides have for this boat to float in perfectly calm water? in cm
i have that F_B (buoyancy force) is equal to W_boat (weight of boat) is equal to W_B + 2*W_s1 + 2*W_s2. where w is the weights and it equal rho*g*V. F_B = density of water*g*total volume and total volume is equal to 6*9*(h+ .05)
any suggestions would really help
Give this a try:
[tex]Weight_{bottom} + 2\rho_{steel} g \ h (L + W) = \rho_{water} g (L-2\times0.046)(W-2\times0.046)(h-0.05)[/tex]
To calculate the minimum height for the sides of the steel "boat" to float, we need to determine the buoyancy force (F_B) and the weight of the boat (W_boat). We can use the formula F_B = W_boat, where W_boat is equal to the weight of the boat (W_B) plus the weight of the two sides (W_s1 and W_s2).
First, let's calculate the weight of the boat (W_B). This can be found by multiplying the density of steel (7900 kg/m^3) by the volume of the bottom of the boat (6.00 m x 9.00 m x 0.05 m). This gives us a weight of 2,385 kg.
Next, we need to calculate the weight of the two sides (W_s1 and W_s2). Since the sides are made of steel, we can use the same formula as above, but with a different volume. The volume of one side is 6.00 m x h m x 0.0046 m (where h is the height of the sides). So, the total weight of the two sides is 2 x (7900 kg/m^3) x (6.00 m x h m x 0.0046 m) = 87.48 h kg.
Now, we can plug these values into the formula F_B = W_boat. This gives us 2,385 kg + 87.48 h kg = F_B. We also know that the buoyancy force (F_B) is equal to the density of water (1000 kg/m^3) multiplied by the total volume of the boat (6.00 m x 9.00 m x (h + 0.05 m)). So, we can set these two values equal to each other and solve for h.
2,385 kg + 87.48 h kg = (1000 kg/m^3) x (6.00 m x 9.00 m x (h + 0.05 m))
Simplifying this equation gives us:
2,385 kg + 87.48 h kg = 54,000 kg x (h + 0.05 m)
Dividing both sides by 54,000 kg gives us:
0.04417 + 0.00162 h = h + 0.05
Subtracting h from
