Calculating the potential of a uniformily charged spherical solid
The discussion revolves around calculating the electric potential of a uniformly charged solid sphere, with a focus on both the interior and exterior regions relative to the sphere's radius and total charge. The problem references using infinity as a reference point for potential.
  • Participants explore the implications of the sphere being uniformly charged versus being a conducting sphere, questioning the assumptions about the electric field inside the sphere. There are attempts to apply Gauss's law and considerations of charge distribution.
Some participants have offered insights regarding the nature of the electric field inside the sphere, suggesting that it may not be zero as initially assumed. There is an ongoing exploration of the implications of the sphere's charge distribution and its effects on potential calculations.
Participants note the lack of specification regarding whether the sphere is conducting or insulating, which is central to the discussion. There are references to textbook examples that may influence the understanding of the problem.
noblegas
Find the potential inside and outside uniformily charged spherical solid whose radius R and whose total charge is q.use infinity as your reference point
[tex]V=-\int E* dl[/tex]
gauss law = [tex]\int E *da=q/\epsilon_ 0[/tex]
This should be easy. Inside a solid sphere, E=0 so the potential inside sphere is zero. The electric field of a sphere is : [tex]E_sphere=(1/(4*\pi*\epsilon_ 0))*q/R^2[/tex] => [tex]V=-(1/(4*\pi*\epsilon_ 0))*q/R[/tex]. Hmm... my solution is too easy; I know this solution was worked out in one of the examples found in my textbooks. Should I apply gauss law I take into account that [tex]dq=\rho*d\tau=\sigma*da[/tex] where [tex]d\tau=(4/3)*\pi R^3[/tex]and[tex]da=4*\pi*r^2[/tex] ?
The electric field is only zero inside a conducting sphere. This is because all the charge migrates to the surface and it acts likes a hollow charged shell. In the question it does not say the sphere is conducting, it says it is uniformly charged. Therefore it must be acting as an insulating sphere, because a conducting sphere is not uniformly charged. Work it out assuming there is a field inside and you will get the right answer.
Also the potential inside a conducting sphere won't be zero, it will assume the value of the potential at the surface of the sphere.
I think I got it; for r>R, E(4*pi*r^2)=rho*(4/3*pi*R^3)/epilison_0 => and for R<r E(4*pi*r^2)==rho*(4/3*pi*R^3)/epilison_0
Yep that looks right.
  • · Replies 42 ·
