Calculating the Torque for a Hand-Driven Merry-Go-Round
  • Thread starter kaite
    Torque
3 replies · 9K views · last reply
kaite
A dad pushes tangentially on a small hand-driven merry-go-round and is able to accelerate it from rest to a frequency of 18 in 13.0 . Assume the merry-go-round is a uniform disk of radius 3.0 and has a mass of 760 , and two children (each with a mass of 21 ) sit opposite each other on the edge.
Calculate the torque required to produce the acceleration, neglecting frictional torque.
What force is required at the edge?
torque= I alpha
w=2pi f
w=w0+alpha *t
change f to w
w= 2pi *.3rev/sec w=1.8849
find alpha
w=w0+ alpha*t 1.8849=alpha*13 alpha = .144997
find I
I= .5 MR^2= 3609
torque= I alpha = 3609*.144997= 523 this answer was incorrect I do not know why I also tried it with I for a hoop the answer was 1046 but this answer was also incorrect if you can tell me where i messed but that would be very helpful thanks
Hi kaite, welcome to PF.
Please add units to all given numerical quantities and restate the problem. Without them it will be difficult to troubleshoot your work.
A dad pushes tangentially on a small hand-driven merry-go-round and is able to accelerate it from rest to a frequency of 18 rpm in 13.0 . Assume the merry-go-round is a uniform disk of radius 3.0m and has a mass of 760 kg, and two children (each with a mass of 21kg ) sit opposite each other on the edge.
2. Homework Equations
torque= I alpha
w=2pi f
w=w0+alpha *t
3. The Attempt at a Solution
change f to w
w= 2pi *.3rev/sec w=1.8849 rad/sec
find alpha
w=w0+ alpha*t 1.8849=alpha*13 alpha = .144997rad/s^2
find I
I= .5 MR^2= 3609 kg m^2
torque= I alpha = 3609*.144997= 523 N M this answer was incorrect I do not know why I also tried it with I for a hoop the answer was 1046 N M but this answer was also incorrect if you can tell me where i messed but that would be very helpful thanks
The question is what torque is required for this acceleration and what force is required at the edge?
Consider the children. They add to the moment of inertia of the system.
Forget the hoop. The problem specifically says that the merry-go-round should be considered as a disk.
