Calculating the wavelength of an electron
The discussion focuses on calculating the wavelength of a beta particle (electron) with an energy of 4.35 × 104 eV. Participants emphasize the importance of converting electron volts to joules using the conversion factor of 1.6 x 10-19. The correct approach involves applying relativistic equations, specifically λ = h/p, where p is the relativistic momentum derived from the kinetic energy of the electron. The discussion highlights common pitfalls, such as misapplying equations meant for photons and misunderstanding energy unit conversions.
  • Understanding of relativistic physics, specifically kinetic energy and momentum
  • Familiarity with the equations E = hf and λ = h/mv
  • Knowledge of unit conversions between electron volts and joules
  • Basic grasp of quantum mechanics concepts
  • Study the principles of relativistic momentum and its application in particle physics
  • Learn about the relationship between energy, frequency, and wavelength in quantum mechanics
  • Explore detailed examples of converting between electron volts and joules
  • Investigate common mistakes in applying equations for particles versus photons
Students in physics, particularly those studying quantum mechanics and particle physics, as well as educators looking to clarify concepts related to energy conversions and wave-particle duality.
bobsmith76
Calculate the wavelength of a beta particle (electron) that has an energy of 4.35 × 104 eV
E = hf
λ = h/mv
V = W/q
eV = .5mv^2
I can't figure out how to get electron volts into a form of energy that I'm familiar with in an equation. I tried
eV = .5mv^2 , but that gave me a speed above the speed of light.
I also tried using E = hf, but that also gave me a ridiculous number.
E = hf
λ = h/mv
V = W/q
eV = .5mv^2
The conversion factor for swapping between eV and Joules is 1.6 x 10-19.
You either divide or multiply depending which way you are changing.
You should know which figure is bigger: either a few joules = lots of eV or a few eV = lots of joules. You thus multiply or divide to get the size of answer you need.
Think: if you multiply by 1.6 x 10-19 will that give a bigger number or a smaller number? Dividing will give the opposite. What size of answer do you want?
1 eV = elementary charge * 1 V=1.602 x 10-19 J.
Apply relativity theory. The given energy is the kinetic energy of the particle (the energy it gains when accelerated by 4.35 x 10 4 V. Find the relativistic momentum, and you get the wavelength as λ=h/p.
ehild
I can't get it. I'm pretty sure I have to divide 4.35 * 10^4 by 1.6 * 10^-19, but that gives me 2.7 *10^23. I then plug that into the equation
E/h = f
which gives me 56 orders of magnitude. I then divide 1.6 * 10^-19 by 4.35 * 10^4 and that also gives me the wrong answer. I have a feeling that my second step of using the
E/h = f equation is wrong.
In what units? You have to get joules.
E/h = f
It is valid for photons. The electron is not photon.
What do you know about Relativity Theory?
ehild
ok, I got the joules to be 7.53 * 10^-18, using this website
http://www.unitconversion.org/energy/joules-to-electron-volts-conversion.html
I don't know how they got that number and would like to know. In any case, I then plugged that number into
.5mv^2 and E = mc^2, using 9.11*10^-31 for the mass. After I got v, I plugged that into
lambda = h/mv
and I was off by an order of magnitude, so I still am doing something wrong.
If dividing didn't work, why didn't you try multiplying?
E/h = f
See above
