Calculating Time for US Debt to Double: Y=1/r ln(x)
  • Thread starter Thread starter sfgradv
    Debt Time
The discussion focuses on calculating the time it takes for the U.S. national debt to double using the formula Y=1/r ln(x), where r is the interest rate and x is the factor of increase. With an average interest rate of 5%, the calculation involves substituting these values into the formula. The concept of compounding interest is emphasized, illustrating how the debt grows over time without additional borrowing or repayment. Participants are encouraged to demonstrate their understanding by applying the formula directly. Ultimately, the discussion aims to clarify the straightforward application of the formula to determine the doubling time of the debt.
sfgradv
Like any loan, the government accrues interest that compounds over time on the amount it owes. If the annual interest rate is r, then the number of years it takes for the amount of money owed to increase by a factor of x is
Y=1/r ln(x)
where ln is the natural logarithm.
The average interest rate on the U.S. national debt is about 5%. If the government neither borrows any more money, nor pays back any of the money it owes, how many years will it take for the total debt to double?
Give your answer using the built-in function ln.
The idea is that you show what you already know,
or how you're thinking, so we know where you're stuck.
Since you already have the formula AND a hint,
maybe you don't know that "double" means "2".
Y=1/r ln(x)
okay, look - it's as easy as filling in the variables with the data that's given.
Y -- that's what your trying to find
r -- that's the interest rate
x -- that's the factor by which it will change
so
r -- what is the interest rate given?
x -- what is the factor given?
it's pretty straight forward
Start amount X e or 2.71 yada yada to the exponent of rate X periods
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
