Calculating Torque for Steel Fixture at 90 Degrees
  • Thread starter Thread starter SevenToFive
    Torque
The discussion focuses on calculating the torque required to rotate a 3600lbs steel fixture made from 10-inch steel channel, which rotates 90 degrees around a pivot point located at its center. The user initially estimates the torque by multiplying the force of 30lbs applied at the end of the fixture (12 inches from the edge) by the distance to the pivot point (60 inches), resulting in 1800 in-lbs. However, participants emphasize the need to account for static friction (stiction), suggesting that the actual torque requirement may be at least double this estimate due to the influence of bearings and lubrication conditions.
  • Understanding of torque calculations and units (in-lbs)
  • Familiarity with static friction and its impact on mechanical systems
  • Knowledge of mechanical design principles, particularly regarding pivot points
  • Experience with steel material properties and their implications in structural design
  • Research the effects of static friction on torque calculations in mechanical systems
  • Learn about gearbox selection and its impact on torque transmission
  • Explore the principles of pivot mechanics and their applications in engineering design
  • Investigate lubrication techniques and their effects on reducing stiction in mechanical assemblies
Mechanical engineers, designers of rotating fixtures, and anyone involved in the calculation of torque for heavy machinery applications will benefit from this discussion.
SevenToFive
The red section of this fixture rotates 90 degrees it weighs 3600lbs, and is 130 inches wide. It is made out of 10 inch steel channel. On the left of the drawing is the dimension of 40" and the pivot point is actually in the center.
We can rotate it by hand if you grab onto the end that is 12" and it takes approximately 30lbs force applied to the end. If we want to add a gearbox to drive this fixture would it simply be multiplying the 30lbs by 60 inches that is the end of the fixture to the pivot point? Giving me 1800 in-lbs? It doesn't seem like enough. Or am I just greatly over simplifying this? Any help is greatly appreciated.
You say the red section rotates 90 degrees, but you do not say what axis it rotates about. The whole question really need clarification.
The red section rotates around the circle which runs through the fixture where the intersection of the red section running left and right and the red portion running up and down.
To be sure we understand, you are actually rotating the arm vertically around the table pivot shaft, correct?
Hopefully this drawing will help clear things up. Thanks to everyone who replies.
Due to stiction (static friction), you wil probably need at least twice that torque to get it started; depends entirely on the bearings and lubricant. I still remember a textbook example from half a century ago that stated: "It takes 10 men to start a loaded railroad boxcar moving but one man can keep it moving."
13K
  • · Replies 19 ·
