Calculating uncertainty in a problem?
  • Thread starter Thread starter bio.student24
    Uncertainty
To calculate the final velocity of a dropped ball, the equation V(final)^2 = V(initial)^2 + 2ad is used, with acceleration measured at 9.8 ± 0.1 m/s² and height at 30 ± 1 m. The calculated final velocity is approximately 24.2 m/s, but uncertainty needs to be determined. By using maximum and minimum values for acceleration and height, the final velocities range from 23.72 m/s to 24.77 m/s, leading to an uncertainty of about 0.525 m/s. This method of using extreme values to find uncertainty is valid and follows basic uncertainty calculation principles.
bio.student24
Calculating uncertainty in a problem??
Hi I have a quick question:
You drop a ball(with zero initial velocity) from the top of a building. If you measure the acceleration to be 9.8 +/- 0.1 m/s^2 and the height of the building to be 30 +/- 1 m, what is the final velocity?
So you would use the equation
V(final)^2 = V(initial)^2 +2ad
v= [(2)(9.81)(30)]^0.5
v=24.249 m/s
Can you explain how to determine the uncertainty of the answer? Thank you!
The ANSWER given was : 24.2 +/- 0.5 m/s
I have tried and this works... but it might have been coincidence.. (can someone verify and possibly direct me to (or tell me) the basic rules when determining uncertainties)
using the MAX values (ie, a=9.9 and d=31)
the answer is 24.77
using the MIN values (ie, a=9.7 and d=29)
the answer is 23.72
then: (24.77-23.72)/2 = 0.525 <-- uncertainty
Is this process completely incorrect? How do you determine uncertainty?
Please help!
help? :(
  • · Replies 38 ·
  • · Replies 20 ·
  • · Replies 16 ·
