Calculating unit vector for velocity
7 replies · 14K views
andykol
Hello,
I am trying to calculate unit vector for velocity (vel= (U*Unit vector)/unit vector). But if I consider calculation by angle change e.g. unit vector= cos(theta) at certain angle velocity becomes infinity.
Please inform me how I can take care of this problem.
Thanks in advance.
This equation makes no sense.
This equation makes even less sense...as cos(theta) is a scalar not a vector.
Typically you make unit vectors by normalizing them, which means to divide by the length.
The unit vector for velocity would be:
[tex]U=\left(\frac{V_x}{|V|},\frac{V_y}{|V|},\frac{V_z}{|V|}\right)[/tex]
where the magnitude of the velocity vector is given by:
[tex]|V|=sqrt(V_x^2+V_y^2+V_z^2)[/tex]
and
[tex]V_x[/tex],[tex]V_y[/tex],[tex]V_z[/tex], are the [tex]x[/tex], [tex]y[/tex], and [tex]z[/tex] components of the velocity vector respectively.
However, without more information on the original problem I'm not sure if this is what you want.
Thanks for reply.
I am trying to multiply velocity with unit vector to transfer velocity without calculating at perticular location. Please see attached picture. Please tell me if I m using right equation and its values.
John,
I need to use following equation to calculate velocity for 2D?
[tex]Unit vector=\left(\frac{U_x}{|U|}+\frac{U_y}{|U|}\right)[/tex]
[tex]|U|=sqrt(U_x^2+U_y^2)[/tex]
Then I can calculate U' by (U(x,y)*Unit vector(x,y))/unit vector(x,y)
andykol said:
Thanks for reply.
John,
I think what you want is the dot product. The dot product will give you the component of the velocity in the direction of the unit vector.
For a unit vector u the projection of V on U is given by:
[tex]Proj_UV=U\cdot V=UxVx+UyVy+UzVz[/tex]
means-
If we consider one direction like picture I have attached in last post.
U- Velocity(known)
U'-Velocity(unknown)
Uv-Velocity Vector
Then if I am transferring velocity value
U'=U.Uv
Where [tex]U_v=\left(\frac{U}{|U|}\right )[/tex]
But this becomes U'=U. I think this is wrong as location of velocity changes.
andykol said:
means-
U- Velocity(known)
Uv-Velocity Vector
U'=U.Uv
To make your posts more clear, use subscripts for components of vectors. Now reread my last two posts. As far as I understand your problem, you are trying to find the component of the velocity in the direction of the unit vector. This is not the same thing as finding the velocity.
