Calculating Velocity of a fluid (by thermal convection) from the heater power.
The discussion revolves around calculating the mean fluid velocity in a closed circuit system heated by an electric heater, specifically focusing on deriving this velocity from the power supplied to the heater and the resulting temperature rise. The context includes theoretical calculations and practical measurements related to thermal convection in fluids.
  • Homework-related
  • One participant describes the experimental setup involving a closed circuit of tubes filled with water and asks for help with calculating fluid velocity based on heater power and temperature rise.
  • Another participant suggests that the problem can be approached as a conservation of energy issue, indicating that most of the heater power is converted to heat, which contributes to the fluid's velocity.
  • A later reply proposes an energy balance equation relating heater power to mass flow rate, specific heat, and temperature rise, and outlines how to derive mass flow rate and subsequently velocity from it.
  • One participant expresses gratitude for the clarification provided regarding the calculation method.
Participants generally agree on the approach to calculate the mean fluid velocity using energy balance concepts, but there is no explicit consensus on the specific assumptions or details of the calculations involved.
Participants do not specify certain assumptions, such as the efficiency of heat transfer or the uniformity of temperature rise, which may affect the calculations. Additionally, the discussion does not resolve how to account for potential losses or variations in flow characteristics.
This discussion may be useful for students or practitioners involved in fluid dynamics, thermal systems, or related experimental setups in physics or engineering contexts.
Igloo_Boobs
Ok, I have some questions to answer for this lab report, and one of them has left me clueless. The experiment was as follows:
An apparatus is made of a rectangular circuit (of known dimensions) of tubes filled with water with thermometers visible at various points throughout the circuit. No water can enter or leave the circuit, only flow around it. The driving force for this is the convection caused by a heat exchanger at the top of one side of the circuit and an electric heater (of known power) at the bottom of the other side.
I have to calculate the mean fluid velocity in three ways.
The first was to simply inject some dye and measure the time taken.
The second was a theoretical calculation using Reynolds and Grashof numbers and what have you.
The third is the one I'm struggling with. Word for word it says "Calculate the mean velocity from the electrical power supplied to the heater and the consequent temperature rise across the heater."
Anyone got any ideas how I could go about part three?
I'm fine with the rest of it, I just have no idea how to appoach part three. I suspect Bernoulli or continuity equations may be involved, and I also think I'm not taking into account some vital piece of information.
TL: DR how can I calculate the velocity of a fluid in a circuit from the power of the heater?
This looks like a conservation of energy problem. You can assume that most of the power is converted to heat. That will be the energy added to the system. What heat not convected away from the module will increase the velocity of the fluid, neglecting pressure of height differences between the inlet and outlet.
Igloo_Boobs said:
...The third is the one I'm struggling with. Word for word it says "Calculate the mean velocity from the electrical power supplied to the heater and the consequent temperature rise across the heater."
An energy balance across the heater yields:
heater power = mass flow rate X specific heat X temperature rise across the heater
Solve for mass flow rate. The mass flow rate is related to velocity as:
mass flow rate = density X velocity X cross sectional area of flow
Solve for velocity.
That's it! That's exactly what I needed. Thanks so much.
