Calculating Work and Potential Energy in a System of Point Charges
The problem involves calculating the work done by an external force to bring a third point charge into a system of two existing point charges on the x-axis. The charges are defined as q1 = -e at x = 0 and q2 = +e at x = a, with the third charge q3 = +e being brought from infinity to x = 2a. The discussion also touches on finding the total potential energy of the system.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the net force acting on q3 and its implications for calculating work. There are questions about the validity of integrating the force from 2a to infinity and whether the work done by the electric force can be equated to the work done by an external force. Some participants suggest that the work can be found by calculating the potential at 2a instead of integrating the force.
The discussion is ongoing, with participants exploring different methods to calculate the work done. There are multiple interpretations of how to approach the integration and the forces involved. Some guidance has been provided regarding the need to integrate the forces acting on q3 correctly, but no consensus has been reached on the correct method or final answer.
Participants are grappling with the integration limits and the forces acting on the third charge. There is a recognition that the forces from both existing charges must be considered, and the discussion includes clarifications about the relationship between the forces at different points along the x-axis.
carnot cycle
Two point charges are located on the x-axis, q1 = -e at x = 0 and q2=+e at x=a.(a)Find the work that must be done by an external force to bring a third point charge q3 = +e from infinity to x = 2a. (b) Find the total potential energy of the system of three charges.
I am struggling with part a of this question
I found that the net force acting on q3 at x = 2a due to the charges q1 and q2 is the following:
F = 3Ke2/4a2
Where K is Coulomb's constant. This was done using Coulomb's law.
Now to find the work done by an external force in bringing the charge q3 from infinity to x = 2a, can't I just find the work done by the electric force in pushing the charge q3 from x = 2a to infinity? Should those two be equal in magnitude? If so, then I obtained the following answer after integration:
W = 3Ke2/(8a)
However, this answer is incorrect. The book states the following: W = 4Ke2/(8a). I am wondering where I went wrong. Thanks.
The work to get from a to b is the difference in potential energy at those points.
F = 3Ke2/4a2
Yes.
W = 3Ke2/(8a)
Well, you didn't integrate the two forces over the distances a → ∞ and 2a → ∞ correctly.
An easier way is to just compute the potential at 2a = V(2a). That requires no integration. V(2a) is the work done to bring a UNIT charge from ∞ to 2a. So the work needed to bring a charge of e to that same spot is
eV(2a).
Why is it incorrect to find the net force acting on q3 (from Coulomb's law) and integrating that force from 2a to infinity?
It's not. I said your integration was not performed correctly.
You have two integrals to perform: one from ∞ to a and one from ∞ to 2a, right?
I integrated the force which I found from Coulomb's Law
∫3Ke2/4a2 * da
This was done from x = 2a to infinity. I pulled out the 3Ke2/4 factor since it is a constant and was left with this.
3Ke2/4 ∫1/a2 * da
The anti-derivative of 1/a2 is -1/a which was evaluated from an upper limit of infinity to a lower limit of x = 2a.
(-1/∞)-(-1/2a) = 1/2a
so then I multiply that with the constant term to obtain 3Ke2/8a but that is incorrect.
I don't see why I have two integrals to find the work done by the electric force in moving q3 from 2a to infinity :/
Because there are two forces acting on your third charge.
One is from -e located at x = 0. So you need to integrate that force from infinity to (2a - 0) = 2a.
The other is from the +e located at x = a, so that force needs to be integrated from infinity to
(2a - a) =a.
Since the +e charge is located closer to 2a than the -e charge you know ahead of time that the total answer will be positive (positive work done ON the third charge).
But don't both charges create a net force that pushes q3 from x = 2a to x = infinity? So shouldn't the limits of integration be infinity to 2a? Sorry that I keep asking the same question. I just can't conceptually grasp it
Take a point x > 2a. The force from the -e charge at that point is ke^2/x^2. The force from the +e charge is ke^2/(x-a)^2. They're different force magnitudes and directions.
OK, you could combine them into one net force F_net = ke^2{1/x^2 - 1/(x-a)^2} and integrate that from infinity to 2a. Same answer.
Remember, this is the force applied TO the third charge to bring it from x = infinity to x = 2a. The force ON the third charge by the first two charges is the negative of F_net. Your integral must be the integral of force applied TO the third charge.
So the force from the -e charge is ke^2/4a^2 and the force from the +e charge is ke^2 /a^2?
and I subtract these two to find that the net force is 3ke^2/4a^2, which I integrate from x= infinity to x = 2a? If so, then i performed these steps in post 6 but did not retrieve the right answer.
You are stating the forces at x = 2a only.
Your integral, as I have said, is from x = ∞ to x = 2a. Study my last post again.
Only at point x=2a ... it does not have that relationship for any other point.
∫3Ke2/4a2 * da ... This was done from x = 2a to infinity
... initially you got the limits the wrong way around, but you fixed that, now what you are saying is that you did this:
$$W=\int_\infty^{2a}F(2a)da$$ ... see the problem?
By the definition of work: the work done moving from point ##x## to ##x+dx## is ##F(x)dx##. To go from ##x=\alpha## to ##x=\beta## you have to integrate over all the values of ##x## in between ##\alpha## and ##\beta##.
What you said you did was $$W=\int_\alpha ^\beta F(\beta )d\beta$$ when you should have done: $$W=\int_\alpha ^\beta F(x)dx$$ ...i.e. you made the substitution too soon.
Leave the equation for the forces as functions of x and then do the integral.
Ohhhh okay, now I see where I went wrong. Thanks so much for helping!
