Calculation of Thomas Precession in Rindler's relativity book
  • Thread starter Thread starter NoobieDoobie
    Relativity
The discussion revolves around the calculation of Thomas precession as presented in Rindler's relativity book. Participants are exploring the implications of velocity transformations and approximations in the context of special relativity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of Taylor series expansions for velocity transformations and question the necessity of certain assumptions, such as ##v' << v##. There is also exploration of the Wigner rotation formula and its relation to the problem at hand.
Some participants have verified results through different approaches and are questioning the completeness of Rindler's problem statement. There is a productive exchange regarding the assumptions made and their impact on the calculations, with no explicit consensus reached on the necessity of certain conditions.
Participants note that Rindler's problem may lack explicit assumptions that could simplify the calculations. There is a recognition of potential calculation errors and the importance of verifying results through different methods.
NoobieDoobie
A problem from Rindller's relativity book (Check below)
Lorentz Transformations
I am trying to work through rindler's relativity book. However, I got stuck at what I think should be a simple approximation.
I calculated the angles ##\theta## and ##\theta''## using the formula for velocity transformation. If I simply expand ##\gamma(v)## and ##\gamma(v')## using taylor series and calculate ##tan(\theta'')-tan(\theta) = \frac{v'}{2vc^2}(v^2+v'^2)##. First term of this formula is precisely the answer. However, I would have to calculate ## tan(\theta''-\theta)##, invert the equation and approximate again. This doesn't seem to be what rindler wants us to do though. There must be a simpler way to derive the formula. What am I doing wrong?
Edit : If I assume ##v' << v##, I do get the same formula as rindler. I checked from Goldstein's book and he derives the same formula under the assumption ##v'<<v##. I am wondering if Rindler might just have forgotten to add it in the problem statement?
Yes, you are right. The assumption ##v' << v## should have been stated by Rindler.
I'm not sure if it's necessary. I found exact formula for wigner rotation under two perpendicular boosts which turns out to be ##tan(\omega) == -\frac{\gamma_2\gamma_1\beta_2\beta_1}{\gamma_2+\gamma_1}##. Which gives the same result as Rindler under the limits ##\beta_1, \beta_2 << 1##. So we don't need to require ##\beta_2<<\beta_1## additionally.
Oh, that's good! And it surprised me. But, I was able to verify ##\tan(\omega) = \large-\frac{\gamma_2\gamma_1\beta_2\beta_1}{\gamma_2+\gamma_1}## after some manipulations using the trig identity $$\tan(\alpha-\beta) = \frac{\tan \alpha - \tan \beta}{1+\tan \alpha \tan \beta}$$.
I should have had more faith in Rindler!
That means I must be doing some trivial calculation mistake since I used same trig identity but my result doesn't match with ##\tan(\omega)##.
Here's an outline of my calculation, which might not be the best.
We know ##\tan \theta'' = \large \frac{\beta \,' \gamma'}{\beta}## and ##\tan \theta = \large \frac{\beta \,'}{\beta \gamma }##.
Here, ##\gamma = \large \frac 1 {\sqrt{1-\beta^2}}## and ##\gamma' = \large \frac 1 {\sqrt{1-\beta \,'^2}}##.
The tangent function trig identity is then $$\tan(\theta'' - \theta) = \frac{\beta \,'}{\beta} \frac {\gamma' - \frac 1 {\gamma}}{1+(\frac{\beta \,'^2}{\beta^2})\frac{\gamma'}{\gamma}} = \beta \beta \,' \frac{\gamma' \gamma - 1}{\beta^2\gamma + \beta \,'^2 \gamma'}$$
It's easy to show ##\beta^2 \gamma = \gamma - \frac 1 {\gamma}## and ##\beta \,'^2 \gamma' = \gamma' - \frac 1 {\gamma'}##.
So, $$\tan(\theta'' - \theta) = \beta \beta \,' \frac{\gamma' \gamma - 1}{\gamma - 1/\gamma + \gamma' - 1/\gamma'}$$
Simplify.
When I had tried it, I first stared at the expression for ##\tan(\omega)## and concluded there's no way it can be as simple as the answer we're looking for. Now I understand why faith plays an important role.
Thanks for the help!
  • · Replies 20 ·
  • · Replies 16 ·
  • Poll Poll
  • · Replies 18 ·
