Calculation: Time for a spring index plunger to release
To calculate the time for an index plunger to fully release, the user describes a mechanism similar to a collapsible loft ladder, where a plunger is compressed against a sliding plate. The sliding plate moves quickly, and the user needs to ensure the plunger releases in time to engage with the plate. Key parameters include the forces at two points (24N at F2 and 9N at F1) and the distance the plunger travels (0.003m). The user seeks assistance in piecing together the calculations, indicating that friction can be ignored for simplicity. A sketch of the plunger is provided for reference.
rustie2013
Hi,
I need to calculate the time for an index plunger to fully release. Can anyone help.
The basic setup is simple. It pretty much identical to a collapsible loft ladder. Within a sliding mechanism, we have a fixed plate and a sliding plate. A plunger is housed within the fixed plate. This plunger is compressed as it is pressed against the sliding plate. The sliding plate has a through hole in it. As this sliding plate slides across the fixed plate the through hole will at some point align with the spring plunger. At which the plunger will be free to release.
The challenge is the moving plate moves very quickly. I need to ensure that the spring plunger can release quickly enough to guarantee the plunger engages into the sliding plate. Can anybody suggest how I can calculate the time for the plunger to release.
Thanks.
rustie2013 said:
Hi,
Thanks.
Welcome to the PF.
Do you have any drawings and/or pictures that you can upload or link to? It's hard to understand the setup just from your word description.
We would also need to know things like weights, friction coefficients, etc., to be able to help you set up the calculations...
Hi, I think for now I can keep things very simple. Friction can be ignored.
All I need to do is determine the time it would take for this index plunger to release. A sketch of the index plunger can be found here:
https://www.dropbox.com/s/vdunol8hvco3q24/Index Plunger.jpg
I need to determine the time for the plunger to travel from F2 to F1.
I know the following:
force @ F2 = 24N
force @ F1 = 9N
Distance plunger can travel Aka distance between F2 to F1 = S = 0.003m
I don't think anything else is needed? I just cannot piece it all together!
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 18 ·
  • · Replies 45 ·
