Calculator Question (Casio) -- How to disable "Shift 9 = AC"
11 replies · 2K views
chriscarson
Calculator issue
Shift 9 = AC
Anybody knows how to take this off because when I m doing for example 0.025 ÷ 2 = is showing the answer with a fraction.
Is it possible to remove the battery for a few minutes? If it's not too hard to do, that might reset it back to factory default configuration.
Ok I can try that. Beleived that with reset on the number 9 button would do the job.well anyway thanks for your help
I tried the battery removal nearly 10 min but still there .
So you used the procedure below?
here it says only how to put it on if I m not wrong.
It shows how to switch modes, I believe. Which one of those 4 modes do you want to be using?
ok it worked, had to choose another function to make it vanish, thanks a lot for your help.
Yay! :smile:
