Calculus 2 interval of convergence -- checking end points
The discussion focuses on finding the interval of convergence for a series and determining the convergence or divergence at the endpoints. The original poster has successfully identified the interval but struggles with the appropriate tests for the endpoints. Participants emphasize the importance of using the ratio test and suggest that if x is negative, the series may be alternating. There is a request for clearer presentation of the problem, as the initial image was unreadable, prompting the poster to provide a new link. The conversation highlights the need for clarity in mathematical communication to facilitate effective assistance.
rossmoesis
[PLAIN]http://email.photobucket.com/wf/click?upn=tRCgAMfEfk8moxY0TjPC4lPPM0sXOKwutyIq47CMTKs0dzyywVYzTaMWH8-2Bzo5-2FsAT1hSn2u8nhtTlXRVI-2BDs3dbLwqV7FVPJZdCfwS6qDorV0c-2Blq6XRnrVUYsLffi2id9Ma4XDGYssMtivke9T0A-3D-3D_whPbjyDNqQqG-2FABCOAcFDhlciHlWVosDuzGNcx8ulLn1XPsw3RItB9a0ZKzbWUjhD5QN0BjKqPT3p-2FFMYnHwCHkxJ8U7UgTdccAw-2BQNDt-2FWYcVOcGYWyPrDnhFZ4wxeKwtHSMH-2FU0Ev-2FD82L-2F5FVMYpPr42BkMfKA0c7B9UFHMZbfml3RpIMxX73T-2BjugVi6TYP6-2BFgjtfKZemv5vG8xCDZrA74p9b7HQm1E0kHNLeQDGCyjMm4HzzVR9GA23nwt
Ratio test
I found the interval of convergence. I'm having a hard time finding the correct test to make sure my end points either converge or diverge. I attached a picture of my work. Some hints would be greatly appreciated.
Ratio test
Your photo is unreadable on my screen. Please type it all out (as per PF standards), but if you still insist on posting an image, at least work at making it usable.
I tried to go back and edit the post but was unable to. This link should work for the problem
http://s30.postimg.org/k3ksocech/scan.jpg
thanks for the heads up.
If x is negative, then you have an alternating series.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
