Calculus II - Alternating Series Test - Convergent?
captcouch
Hello! I was working some practice problems for a Calc II quiz for Friday on the alternating series test for convergence or divergence of a series. I ran into a problem when I was working the following series, trying to determine whether it was convergent or divergent:
[itex]\sum[/itex] (-1)n[itex]\frac{3n-1}{2n+1}[/itex]
n=1
Alternating Series Test:
For an alternating series
[itex]\sum[/itex] (-1)n-1bn
n=1
to converge, it must satisfy the following conditions:
1. bn+1 ≤ bn for all n in the series
2. lim bn = 0
n[itex]\rightarrow[/itex]∞
Test for Divergence of a Series:
If the limit as n approaches infinity of a series does not exist or does not equal 0, the series is divergent.
I first began by analyzing the limit as n approaches infinity for the series. By dividing the coefficients of the highest exponential power of the top and bottom (in this case, 1), I found the limit of the series to be [itex]\frac{3}{2}[/itex]. It did not satisfy the second condition of the alternating series test, and as such, I sought to double-check with the Test for Divergence of a Series.
(-1)n's limit does not exist, as it is always alternating back and forth between -1 and 1.
[itex]\frac{3n-1}{2n+1}[/itex]'s limit, as mentioned above, I found to be [itex]\frac{3}{2}[/itex].
From this information, I concluded that the limit did not exist, and that the series was divergent.
I decided to check the answer from the back of the textbook, and it said it was convergent! I ran through it again a couple of times and got the same result: divergent. I'm not sure what I did wrong here - could I please have some insight from someone else to shed some light on the situation? Thank you very much!
n=1
n=1
2. lim bn = 0
I'll tell you what's wrong here: your book. That series is definitely not convergent.
Man, you've got to be kidding me. Nobody's perfect, I guess. I'll be sure to tell my professor in the morning. Thanks for the help!
The most fundamental theorem about infinite series, typically the first proved in a textbook, is
If [itex]\lim_{n\to\infty} a_n\ne 0[/itex], then [itex]\sum a_n[/itex] does NOT converge.
