Calculus in the velocity and acceleration of satellites.
The discussion focuses on the application of calculus to determine the velocity and acceleration of satellites based on their distance from Earth. The user initially attempted to derive acceleration from the orbital speed equation, v = SQRT(G*M/R), but encountered discrepancies due to misunderstanding the relationship between scalar and vector quantities. The correct acceleration formula, a = G*M/R^2, was confirmed through calculations, yielding an acceleration of 9.53 m/s² for a radius of 6.47 x 10^6 m. The user recognized the need to differentiate velocity with respect to time rather than radius to accurately compute acceleration.
  • Understanding of basic calculus concepts, including differentiation and integration.
  • Familiarity with gravitational physics, specifically Newton's law of universal gravitation.
  • Knowledge of vector quantities, particularly velocity and acceleration.
  • Ability to manipulate algebraic equations and perform unit conversions.
  • Learn about vector calculus and its applications in physics.
  • Study the relationship between velocity and acceleration in the context of circular motion.
  • Explore numerical methods for calculating satellite trajectories using calculus.
  • Investigate the use of trigonometry in determining distances to satellites from Earth.
Students in physics or engineering, educators teaching calculus applications in real-world scenarios, and anyone interested in the dynamics of satellite motion and gravitational effects.
VinnyO
I am working on a project dealing with the velocity and acceleration of satellites based on their distance from Earth. I was recommended to include some calculus in this project. Originally I thought I could just take the derivative of the orbital speed equation to find acceleration, given the mass of the Earth and the gravitational constant would be constants in the situation. When I tested this hypothesis with the accepted acceleration equation the answers came out different. I am fairly sure this is because the remaining variable is R (the radius of the orbit) as opposed to time, but perhaps I am making a different mistake. So at this point I am in search for a way to make calculus relevant in this situation.
v = SQRT(G*M/R)
a = G*M/R^2
I also have been looking for a way to calculate the distance of objects like the ISS from Earth based on observations/ measurements I can take myself (from Earth), but I assume any solution to this would be related to trigonometry or geometry.
Remember that velocity and acceleration are vectors. Differentiating a speed (a scalar) does not give acceleration.
Please post your algebra.
Remember that acceleration is change in velocity with respect to change in time
Moved to Calculus & Beyond section
Thanks for your reply!
Currently I have only taken one year of calculus in which I have not learned vectors (the report is for math in the program I am in and because I have taken calculus I was encouraged to utilize that skill). However with a bit of research on the basics of such I realize how obvious my mistake is. With that in mind my first though was that perhaps I could find velocity given the acceleration formula with some integration. But anyways in short this was my math:
I took an online example where R (the radius of the orbit) was 6.47 x 10^6 m. When plugged into the acceleration formula, a = (6.673 x 10^-11 N m^2/kg^2) • (5.98 x 10^24 kg) / (6.47 x 106 m)^2, a (acceleration) was equal to 9.53 meters per second squared.
To test my idea to use calculus I took the orbital speed equation, v = SQRT(G*M/R), and plugged in the gravitational constant, 6.673 x 10-11 N m^2/kg^2, for G and the mass of Earth, 5.98 x 10^24 kg, for M
I than simplified this to v=998806037 / 50*R^1/2
The derivative of this was a= -998806037 / 100R^3/2
I finally just plugged in the same R value into the new potential acceleration equation, a= -998806037 / 100(6.47x10^6)^3/2, and got a=6.07x10^-4 which was not equal to the answer produced by the equation so I knew I made some wrong assumption.
That is the derivative wrt radius, dv/dR. Acceleration is the derivative of velocity wrt time, dv/dt.
  • · Replies 16 ·
  • · Replies 39 ·
