Can Calculus Proofs Clarify Polynomial Degrees and Factoring Challenges?
This discussion focuses on proving properties of polynomials and factoring techniques in calculus. Key points include the definition of a depressed polynomial, which is one degree less than the original polynomial, and the application of the Rational Root Theorem and synthetic division for factoring polynomials. The polynomial P(x) = x^3 + x^2 - 16x + 20 cannot be factored by simply extracting a constant like 4, as it is not a common factor. Participants emphasize the importance of verifying roots by substitution and using synthetic division for polynomial factorization.
  • Understanding of polynomial degrees and definitions, specifically "depressed polynomial."
  • Familiarity with the Rational Root Theorem.
  • Knowledge of synthetic division techniques.
  • Basic calculus concepts related to polynomial roots.
  • Study the definition and properties of depressed polynomials.
  • Learn how to apply the Rational Root Theorem in polynomial factorization.
  • Practice synthetic division with various polynomial examples.
  • Explore methods for verifying polynomial roots through substitution.
Students and educators in calculus, particularly those dealing with polynomial proofs and factorization techniques. This discussion is beneficial for anyone looking to strengthen their understanding of polynomial properties and methods for solving related problems.
Psybroh
Hi, I've been trying a couple of proofs that my calc teacher gave me, but I'm not sure if I have the right approach or not.
1) Prove that the degree of the depressed polynomial is exactly one less than the degree of the original polynomial.
- For this proof, all I can come up is the face that since a "x" has been removed from P(x), the depressed polynomial Q(x) has 1 less "x" in each of its terms, and therefore has one less degree. is this correct? I cannot seem to express this in terms of variables and numbers.
2) Factor P(x) = x^3 + x^2 - 16x + 20 into the product of a constant and 3 linear factors.
- Can I factor out a 4 and use that as a constant?
3) Show that x=a is a root of x^3 - ax^2 + ax - mx^2 - a^2 + amx = 0, without using synthetic division.
- Do I just plug in x=a into the polynomial and show that the entire thing does come out to zero, or...?
4) Given that x=a is a root of x^3 - ax^2 - ax - mx - mx^2 + a^2 + am + amx = 0, use synthetic division to factor that eight-term polynomial into the product of two factors: one in linear x, one quadratic in x.
- I have NO idea how to even start this... any help would be great! lol
Well, these are it. I have some ideas to solve them, but I'm not sure if they can really be considered proofs. Any help and suggestions would be great! Thanks! :)
Of course not. 4 is not a common factor. Use the rational roots theorem and synthetic division.
Did you try that? Did it work?
Collect terms on powers of x and use synthetic division by (x-a).
(1) ... what is the definition of a depressed polynomial?
Most proofs start out with a statement of definition.
(2) ... what happens when you try?
(As LCKurtz points out, 4 is not a common factor. Had you tried, you'd have got your answer.)
Sometimes the only way to identify the right path is to follow it for a while.
You would be better to try to factorize the polynomial first.
(3) ... what is the definition of "root of a polynomial"?
The comment here is a combination of those for (1) and (2) ... try it and see.
(4) if "a" is a root of the polynomial, then "(x-a)" is a factor.
How would you normally go about factorizing a polynomial?
This is giving me deja-vu ... anyway, LCKurtz has given you some good clues if you don't know some of the theory. It is all stuff you can look up. Let us know how you got on.
  • · Replies 18 ·
  • · Replies 24 ·
  • · Replies 18 ·
