Calibrating a pH electrode and preparing a salt solution
4 replies · 8K views · last reply
kawaiitora
Hi,
I need some help with a few problems. Thanks!
(1) You have a pH Electrode that reports a voltage in
mV, which is proportional to the hydrogen ion concentration
in solution. You also have pH buffers at known pH of say
4, 7 and 10. What do you do to translate the mV reading
into pH values for any given solution with pH between
4 and 10?
(2) You have DI water plus CaCl2 and NaHCO3 salts.
What do you do to prepare a solution with Ca concentration
of 10 mmol/l and total C concentration of 2 mmol/l?
Hi there kawaiitora and welcome to PF,
What are your thoughts on the problems?
Thanks for the quick reply. Sorry, I forgot about that.
(1) I'm thinking that I should use the Nernst equation, but I'm not sure which variation would be the best.
(2) For this one, I'm really not sure how to start. would I need to make up a molecular equation first?
No problem, let's take each problem in turn.
Question One
You should first start with the basic Nernst Equation;
[tex]E = E^{\theta} - \frac{RT}{nF}\cdot\ln Q[/tex]
Now, how many moles of electrons much be transferred to balance the charge on Q (which in this case is the hydrogen ion)? If we also assume standard conditions we have sorted the [itex]\frac{RT}{nF}[/itex] coefficient. Now, the next thing you should do is convert the natural log into a log to the base 10; this involves a little bit of mathematics but is petty straight forward. Next, you will want to express Q in terms of hydrogen ion concentration or activity. After which, all is plain sailing :smile:. Can you go from here?
Yep. Thanks, Hootenanny! Now, I need some help with the second problem...
