CAMAC crate electronics - Where were/are they used?
  • Thread starter Thread starter Christoffer B
    Electronics
The discussion revolves around the CAMAC standard in nuclear electronics, exploring its historical usage, prevalence, and relevance in current experimental setups. Participants share insights on the system's adoption compared to other standards like NIM and VMEbus, as well as their personal experiences and observations regarding its application in laboratories.
  • Some participants express curiosity about the historical prevalence of CAMAC systems and inquire about specific experimental setups where they were utilized.
  • One participant notes that CAMAC was less common than NIM systems but allowed for module communication, albeit with reliability issues.
  • Another participant mentions that CAMAC systems are still operational in some older detector arrays and accelerators, with companies producing compatible modules.
  • Historical usage at the Rutherford Laboratory in the 1970s is highlighted, with a comparison to a different modular system used at Harwell.
  • Concerns are raised about the cost of CAMAC modules being significantly higher than both NIM and VME modules.
  • Some participants argue that while CAMAC may be niche, certain components like nuclear ADCs remain unique to its field.
  • A suggestion is made to contact nuclear physics labs for potential acquisition of old CAMAC equipment, indicating ongoing use in facilities with limited budgets.
Participants generally agree that CAMAC has historical significance and some current applications, but there is no consensus on its prevalence compared to other systems like VME. The discussion reflects multiple competing views on its relevance and usage in modern contexts.
Participants express uncertainty regarding the extent of CAMAC's usage outside the US and the specific experimental setups that employed it. There are also unresolved questions about the cost implications and the longevity of CAMAC systems in current laboratory settings.
This discussion may be of interest to individuals researching historical nuclear electronics, those involved in experimental physics, or collectors of scientific equipment.
Christoffer B
TL;DR
Looking into the history of CAMAC crate electronics for physics/high energy setups.
How common were/are they? In what setups were they used?
Hi!
I've done some research on the CAMAC standard of nuclear electronics - "It's like NIM but digital" - as I would like to acquire a bin and some modules for historic and scientific curiosity.
I have never worked with the system, and I would like to get in touch with somebody who has. How common were they ever? And in what experimental setups were they used?
There is a short handbook 'A CAMAC Primer' written and distributed at LANL, which can be found online, but It's not the most helpful text.
Were Europe favoring VMEbus systems over CAMAC? I can find very little evidence of them being used outside of the US.
Any insight would be much appreciated!
--Chris
A little less than NIM.
It was like NIM, but modules could communicate. So instead of a rat's nest of cables in the front, you had fussy and unreliable communication on the backplane. This is called "progress". 😈
Lots of places...fifty years ago. It's at least four standards back.
Good to know, thanks! I know it's oldschool, but as far as I've heard, they're still running on some older detector arrays and accelerators. There are a few companies still producing modules in the standard, even USB/ethernet crate controllers. SOMEONE must be buying them, even if it's only to keep old setups alive.
They were used a lot at the Rutherford Laboratory, next to Harwell, in the 70s.
Harwell had its own modular system - I forget the name - based on a module about 3" wide where 5? fitted in a single shelf. I remember being a little envious that Rutherford had these much slimmer CAMAC systems and I couldn't get my hands on them.
That's interesting to know. I have read that CAMAC modules were massively more expensive than both the preceding NIM modules and the VME ones that replaced them.
CAMAC was a niche market. VME is in much wider use.
The base bus and racks might be, but the nuclear ADCs and coincidence modules are still pretty unique to that field. The general construction of VME modules are simpler, though.
Hi,
If you want to buy some old stuff, you may ask the main nuclear physics labs/facilities in your country, they can tell you if they are using them, or planning to get rid of some CAMAC crates/modules. If they have some old modules and they are not in use, maybe they can give them to you free of charge.
CAMAC is still on use in some facilities which have been operating without uninterruptedly in the last 20 years (or even more), and also laboratories which have a low budge and they have to use what they have at hand...
Regards,
ORF
  • · Replies 19 ·
  • · Replies 25 ·
  • · Replies 41 ·
  • · Replies 25 ·
  • · Replies 17 ·
9K
