Can 3D Objects Exist in Higher Dimensions?
7 replies · 2K views · last reply
LightningInAJar
TL;DR
Higher Dimensions.
Assuming there are higher spatial dimensions are there things that exist in 3D that actually cannot exist in higher dimensions? Maybe even dimensions?
Yes. Knots. They only work in 3 dimensions.
You can't tie a piece of string into a knot in 2 dimensions, and in 4 or more, they just fall apart*.
* Unless you make a knot of a 3 dimensional object
So all higher dimensions make knots impossible? Or just even ones like 4th, 6th, 8th, etc?
Anything else not possible?
Nothing to do with odd/even.
Sure.
A true circle (or square, or whatever) is technically a two dimensional object. It can only physically exist to us if it has a third dimension. Likewise, a cube is a three dimensional object and would need a fourth dimension to physically exist in a four-dimensional world.
So you would say adding a dimension doesn't corrupt any information held within a lower dimension regarding the objects contained therein?
Well, now we're in a pickle. What do you mean by "adding" a dimension?
Either there are three dimensions or there aren't. Either there are four (spatial) dimensions or there aren't.
I know of no way, even in principle, of changing the number of dimensions on-the-fly.
A better question might be: is a 3D cube in three dimensions identical to a 3D cube in four dimensions?
I'd say the answer is no.
A circle in Flatland is not the same as a circle in our 3D world. It is a physical, impassible barrier to Flatlanders, whereas to us, it can't even exist without being given a thin 3 dimensional height (such as ink on a paper).
I don't mean creating dimensions on the fly. Assuming as many (perhaps more) as 8 dimensions exist. No information is lost or unattainable while looking at a higher dimension when trying to see 3D space? Perhaps we don't see a 3D knot as a knot at all in 4D, but can still recognize that it is a knot in 3D?
