Can a bio-fuel based energy be future houses?
  • Thread starter Thread starter dan020350
    Energy Future
24 replies · 9K views
dan020350
I was thinking what is the cost efficient and energy efficient way for the new future homes to be.
Since alternative energy like solar and wind is not efficient enough (10%) then I was thinking maybe bio-fuel or algae be the way to be independent from the utlitity companies.
The objective is to make the home free from all expenses, a dream house for the sages.
10% efficiency is just fine if the energy source itself is free. For solar and wind, the key consideration is not efficiency, it is the initial capital cost of the installation.
They used to use "cow patties" for fuel on the Great Plains! Anything that is widely available and cheap will be utilized when the snow flies.
That doesn't necessarily make it the best use.
I was thinking about the algae farm, rather cow patties but about the solar and is it a solution for the urban community?
No. Algae farms require extensive and expert care and feeding. All kinds of things can go wrong. The output from algae farms is algae, not oil. The next step is converting that algae to "algae crude". This requires a different kind of extensive and expert care and feeding, and the process also involves some rather nasty chemicals as inputs and produces some rather nasty chemicals as byproducts. All kinds of things can go wrong. Converting that to algae crude to a usable product requires yet another king of extensive and expert care and feeding.
If you have a big inheritance begging to be wasted plus PhDs in biology, chemistry, mechanical engineering, and petroleum engineering, then yes, a DIY algae farm that ultimately produces usable fuel is a real possibility.
I am not disparaging the concept of biofuels from algae per se. I am disparaging the notion of a backyard DIY project. There are huge economies of scale at play here, and a wide range of technical expertise is needed to make such ventures successful.
Perhaps the easiest way to understand the challenge is to consider the economic potential per square foot, and compare this to any reasonable estimate of operating costs. If we assume the very generous case of 4000 gallons of fuel net [after production energy losses] per acre-year, then we might expect a user value of around $16000 per acre-year of algae. With 43,560 square feet per acre, we net about 37 cents per square foot per year.
Try to build, operate, and maintain a bioreactor or even a raceway for that price. The energy required for aeration alone can kill the budget.
NascentOxygen said:
There was a ripple of excitement in some circles a few years back with the discovery of an alga whose byproduct of photosynthesis is H2 gas. Things seem to have gone quiet, though; maybe it didn't live up to its promise?
Hydrogen from algae is a more distant goal. Though there is an effort in Spain to produce methane from algae that seems most promising. Their approach allows the use of fast-growing strains of algae not suitable for oil production.
https://www.physicsforums.com/showpost.php?p=4557502&postcount=534
There is work to improve the efficiency of algae for hydrogen production.
Recent papers on the same green alga species indicate that it is possible to genetically eliminate certain competitive electron-utilizing pathways, and that directing more electrons instead towards the cell’s hydrogenase does increase hydrogen production. In an industrial setting, green algal mutant strains optimized for hydrogen gas production would be cultivated in a sealed bioreactor and the hydrogen gas produced would be collected and stored for use in fuel cells.
Dubini said that day could be a long way off, noting that so far this is just fundamental science. “But by exploring all the different barriers to hydrogen production we are gaining a much better understanding of the functions of the ferredoxins and their involvement in hydrogen production – and that is very exciting,” she added.
The work was supported by DOE’s Office of Science.
http://www.nrel.gov/news/press/2014/8301.html
A group of researchers at Uppsala University, led by Senior Lecturer Fikret Mamedov and Professor Stenbjörn Styring, have now made a discovery that changes the view on hydrogen production from green algae. The researchers studied in detail how Photosystem II works in two different strains of the green algae Chlamydomonas reinhardtii. By measuring exactly how the amount and activity of Photosystem II varies under different conditions, and thereby affects hydrogen production, they found that a considerable amount of the energy absorbed by Photosystem II goes directly into hydrogen production.
"As much as 80 per cent of the electrons that the hydrogen-producing hydrogenases need come from Photosystem II, which is much more than previously believed. This means that most of the hydrogen production is driven directly by solar energy. The discovery gives us hope that it in the future will be possible to control the green algae so that the efficiency becomes significantly higher than it is today," says Professor Stenbjörn Styring.
http://www.sciencedaily.com/releases/2013/04/130415182430.htm
Everyone provide good information, but we will eventually make a decision. What is your decision of obtaining the goal?
The market will make the decision based on price. If [and I believe when] algal fuels are competitive at the pump, you will be using algae-derived fuels.
Origin Oil is becoming a major player and claims to be nearing a competitive price for algae oil.
https://www.youtube.com/watch?v=tzWvl9WDBnw
We will just have to wait and see if they can produce as claimed.
Use steam from boilers fueled by wood. You could so almost anything with the steam engines -- heat, cool, generate electricity. Wood isn't free, but it is inexpensive. If you measure efficiency in terms of acres of land and labor needed, most bio fuels would have a hard time beating wood.
Warning: wood fired boilers have been banned in many places because the emit so many pollutants; but that wasn't part of your question.
It would be impossible to power the country on wood. It is only an option right now because very few people depend on wood for power - there is very little demand.
How long does it take to replace a forest? Algae can double in mass as often as every few hours, though most good oil producing strains may only double in mass once every day or two. How long does it take a tree to double in mass?
I had five acres with about two acres of large trees, and we couldn't grow trees fast enough to use all wood heat [just space heat]. Had we tried, eventually all two acres of trees would have been gone.
hmmm... So If I were to build a 500 ft2 algae eve around my house, I could expect to get 40 gallons a year? Seems adequate.
Jay Leno consumed only 4.65 gallons of gas in his Volt over the course of a year. I suppose if he had solar panels on his roof, that would provide his primary source of energy.
(ref)
Meshing the infrastructure technologies of electrical(two-way) transmission, and natural gas(one way) delivery, I don't see much of a technological barrier to creating a community wide algae transport system. Kind of like the sewer system, only a green algae slurry, flowing to a central processing facility. Economies of scale, of course. You wouldn't want everyone to buy a bio-reactor. The 35 extra gallons of fuel produced from each home could be sold to fuel semi-trucks, and ships, and reprocessed into jet fuel.
So if we put this 500 ft2 eve on all 70,000,000 single family dwellings (ref), that would generate about 2.5 billion gallons of excess fuel a year, assuming we all drove Volt type cars.
Eeek! Airline fuel consumption for 2013: 10 billion gallons. (ref)
It's best to do the math, before implementing some of my ideas. :redface:
I have 1/6 acre, and cut down two trees, twenty years ago. I just used the last of it. Put a sweater on! :-p
Though I did only burn fires on the weekend, and used electric heat on the weekdays.
Most likely you'll get a festering, stinking pond of yuck with zero economic value. This will result in tons of complaints from your neighbors to your municipality about the unsightly, stinky, and disease-ridden mess in your backyard.
Algae normally does not produce fatty acids and lipids. You need to feed it just right, stuffing it with some nutrients but seriously starving it of others to make that algae capable of producing oils. Do that just right and now you have a new problem: The algae is susceptible to all kinds of problems because you have intentionally stressed it to near death. You need a PhD in biochemistry to successfully manage your backyard algae pond.
Suppose you do manage to keep your backyard algae pond on track and can regularly skim oil-laden algae from your pond. You now have to separate the water, chlorophyll, and other stuff from the oils. You need a backyard centrifuge to squeeze the oils out of the scum you drained off your pond. If you have a dual PhD in biochemistry and mechanical engineering you might have the wherewithal to accomplish the first task and the second.
Do this just right and you'll have green sweet light crude. Pour a gallon of sweet light crude in your car and you'll have a car that no longer works. You need a backyard refinery to convert that green sweet light crude into usable fractions. That means a third PhD, this time in chemical engineering, and that means even more complaints from your neighbors.
The way to overcome the first two problems is to make the project much bigger than a backyard DIY algae farm. Now economies of scale can kick in. The way to overcome the third problem is to sell the green sweet light crude to a refiner.
The only remaining obstacle is to somehow make a profit on those sales. That turns out to be the biggest problem of all.
What are the mechcanic and logistics from algae to oil?
Actually, my design is based on the carport I built several years ago. I purchased clear poly-carbonate sheeting, as it's already dim here, and my house was surrounded by 100 foot tall Douglas Fir trees. Even their branches can kill you, if they snap off.
My idea was to double up the sheets, creating a closed channel system.
ps. Live algae doesn't stink. Dead algae stinks.
I don't have a degree in anything, and I have no delusions of doing such a project on my own.
This is why I alluded to creating a secondary sewage type system. Algae is harvested and flushed to a core facility with all the gadgetry: centrifuges, refineries, etc. etc.
The only gadgetry required at the home would be the liquid filled house eave, a water pump, a gas pump, a filter, and a flush valve.
Well, the only reason Jay Leno used any gas at all, from my recollection, was because the gas will get stale after awhile. My carport cost about $1 per square foot, and is ≈200 ft2
Though that was ≈20 years ago when I originally installed it.
google google google
$25.94
Suntop 26 in. x 12 ft. Castle Grey Foamed Polycarbonate Corrugated Roof Panel
It looks as though the price has doubled, so I'm guessing $2/ft2*500 ft2= $1000
With production at 40 gallons per year, and diesel @ $4/gallon, that's $160/year, which yields a return on investment of 6.25 years.
Since most homes come with eaves in the first place, it might be sooner. But since I've not calculated in all the cost, it would probably be longer.
But, IMHO, doing something expensive, is better than doing nothing at all, and continue to watch $400,000,000,000 per year being drained from our economy, which is what Stephen Chu said was the cost of imported crude oil, when he came to visit my former employer awhile back.
Ah ha!
OmCheeto said:
Professor Chu has entered the room. :smile:
Apr23-13, 05:55 PM
hmmm... I have this weird suspicion that I'm repeating myself...
OmCheeto said:
I guess my point is that we shouldn't get pissy when people experiment with different methods(political, economic, etc.) of energy conservation, we should get pissy when they do nothing at all.
Nov7-09, 12:05 PM
:redface:
I just discovered that Oregon couldn't even power Oregon with our wood, even though we are ranked 39 in population density. (based on some wild estimates)
5,000,000,000 annual sustainable harvest of Oregon trees in board feet (ref)
~46 megajoules/kg of Gasoline (petrol) / Diesel / Fuel oil
16.2 megajoules/kg of wood
(ref)
29,201,748,097,500 watt hours of sustainable Oregon forest(annual)
46,800,000,000,000 Goonie* watt hours/yr consumption(based on my electrical usage and number of fellow Goonies)
And that's at 100% efficiency. I seriously doubt my old Franklin stove has an efficiency over 0.1%.
I estimate my two trees were between 50 and 75 years of age. Interpolating a 7 day/week vs 2 day/week burn cycle, I would have burned all my wood in less than 6 years. Hardly sustainable.
I wonder how long it would have lasted, with modern technology
Winning Wood Stove Designs Announced
The use of wood for residential heating in the United States has increased nearly 40 percent over the past decade, according to government figures. And Europe, where wood pellet stoves are widely used, has been at the forefront of developing wood stove technology, said Ackerly and others. (See related: "High Fuel Costs Spark Increased Use of Wood for Home Heating.")
bolding mine
I didn't see any quoted efficiency numbers. Though I've seen numbers quoted for natural gas units in the mid 90's.
hmmm... I wonder what would happen if we utilized the CO2 from wood stoves to feed our algae eaves? The hundred or so trees, on my 1/6 acre lot, do grow vertically.
hmmm...
Didn't a 12 year old design a 3 dimensional solar panel awhile back?
Yup
Beaverton boy lauded for solar cell invention
BEAVERTON, Ore. – A new invention could revolutionize solar energy – and it was made by a 12-year-old in Beaverton.
Despite his age, William Yuan has already studied nuclear fusion and nanotechnology, and he is on his way to solving the energy crisis.
It all started with Legos - after he learned nanotechnology to make robots take off. The seventh grader then got an idea inspired by the sun.
"Solar it seems underused, and there are only a few problems with it," Yuan said.
Encouraged by his Meadow Park Middle School science teacher, the 12-year-old developed a 3D solar cell.
Have I ever mentioned the fact, that I love being surrounded by smart people? :smile:
*Goonie: self-depricating term used by persons from Oregon when referring to each other. Portmanteau of Goon(generally a bad thing) and Oregon(nice place to live). See also: Orygoonian.
Prays* for more wisdom
Qingtao china overproduction algae beaches
Been there, were awed by that. :wink:
Apr11-09
Ivan Seeking said:
http://green.yahoo.com/blog/ecogeek/1023/venice-to-use-algae-for-50-of-its-electricity.html
I couldn't help but think of this scene
http://www.nytimes.com/2008/07/01/world/asia/01algae.html
https://www.youtube.com/watch?v=Y7ZJkd2d8vQ
It seems likely that algae biomass could be used to replace coal and natural gas, for power plants. Many of the existing challenges in using algae for fuel production, such as for biodiesel, could be avoided.
https://www.youtube.com/watch?v=aly5Xese4m0
These guys are doing things the old-fashioned way, which probably means that their oil costs in the $20-$30 per gallon range. And if we assume their bioreactor is something close to 20' x 200', then we have about 4000 sq feet. At 43560 sq feet per acre and an ideal yield of 4000 gallons per acre-year, then they might expect the ideal case to be something less than 400 gallons per year. Processing efficiency is typically cited to be something around 40%, so the ideal case is a net yield of about 150 gallons. But the truth is that they may well use more energy to produce the algae oil than they get back. It depends largely on the bioreactors design and method operation, and the efficiency of the oil extraction process. Oil presses are very inefficient. Also, in practice I would expect the yield to be much less than that estimated above, depending on location, climate, algae strain, and a range of other variables.
Even if we assume that you manage to maintain the crop successfully, you still haven't paid for the cost of start up and operations. You could theoretically have $160 worth of oil but it would probably cost you more than that to produce. When I say net yield, I am talking about the energy cost of production - actually just the energy cost of processing. But net net is the point at which you make a profit - it includes all of the energy used to process the algae, as well as the energy to grow the algae and the cost of building and maintaining your system. You are ignoring the most important points such as, just the cost of aeration can kill the budget! Things have improved, but back in 2007, I couldn't see any model yielding a profit until we were talking about very large farms. I think the first break even point that I could find was at around 10,000 acres, and that was based on a number of reasonable but unproven assumptions.
Yes, bacteria and viruses are a constant threat, as are low-yield indigenous strains. The first thing a biologist wants to do when you talk about growing algae is to put everything in an autoclave.
Evolution has already fixed that in a different different system. I recently came across some research in the UK on leaf-cutter ants. The ants feed leaves to a fungus which provides them with food. To protect the fungus against bacterial attacks, the ants synthesize a cocktail of antibiotics which are transferred from their skin to the fungus.
As one of the researchers put it, this was one of the most sophisticated systems of agriculture on earth, millions of years before humans started farming. The bugs haven't managed to become resistant to the ant antibiotics over a timescale of millions of years, compared with the 50 years it took for the bugs to defeat the first human-produced ones.
