Can a dimensionless point have intrinsic spin and create forces?
  • Level: Graduate
  • Thread starter Thread starter LotusPond_14
    Point
50 replies · 8K views · last reply
LotusPond_14
hi there...
what is a point in a space?
classical math tells us that a point is:
- an exact location on a plane surface
- it has zero dimension
but it can be viewed of as
- an origin of fundamental forces operating within a dimension. all forces in a dimension must have an origin, thus, it is logical that a point within that dimension must be responsible to create the force.
- it has no dimension but movement or activity can be observed. this follows that a point though it has no dimension, the only way that activity is evident is for the point to have rotation. it also follows that it can rotate either left handed, or right handed.
- the point's spin also, is not confined to a certain plane in a dimension only. for example, in a three dimensional "space", the left handed or right handedness of the point's spin only denotes orientation since the point can spin in all directions.
can you please help me on this if my observations are correct or not beacuse recent physics experiments clearly are going to the direction of this observation.
my origin of the claim is from the central force problem of classical mechanics which aims is to determine the motion of a particle under the influence of a single central force. A central force is a force that points from the particle directly towards (or directly away from) a fixed point in space, the center, and whose magnitude only depends on the distance of the object to the center. (from wiki pedia).
the problem applies for bodies having mass (thus having their own dimension in the case within three dimensional space as having length, width and height) but can it be extended to the smallest unit of space available within a dimension (ie the distance between two zero dimensional points in a one dimension subset or dissection in a 3d space) and the interaction of the forces transferred from one point to the next.
Per wiki: http://en.wikipedia.org/wiki/Point_(geometry )
In modern mathematics, a point refers usually to an element of some set, called space.
More specifically, in Euclidean geometry, a point is a primitive notion upon which the geometry is built. Being a primitive notion means that a point cannot be defined in terms of previously defined objects. That is, a point is defined only by some properties, called axioms that it must satisfy. In particular, the geometric points do not have any length, area, volume, or any other dimensional attribute. A common interpretation is that the concept of a point is meant to capture the notion of a unique location in Euclidean space.
Note the last sentence. A point is not a physical object. It is a mathematical concept. We can consider objects and events to be located at a point, but we cannot say that the point itself creates anything or is responsible for anything, nor can it have a spin. It's just a way to keep track of the location of things in space.
so how does a force act upon a point in space? does it only transiently convey ; transmit the force into space since it is implied in classical math that it is only a notion to keep track of location of things in space?
A force does not act on a point in space, it acts on an object located at that point in space. These interactions are governed by well understood laws.
but those laws as i researched does not have conformity when describing forces within very small objects and forces that govern massive objects why is that so?? i believe in the notion that all forces operating in a dimension must be the same whether the force is acting on a small object or it acts on a massive object and everything in between.
thus it follows that in order for forces acting on objects are the same, the medium in which the objects exist must be of the same "viscosity", (i am describing viscosity because it is observed that space acts like it and is documented in various scientific journals.) but as objects tend to be more massive than others it is logical that the space encompassing massive objects tend to be more stretched than less massive objects.
now, what does space comprises of? is it just a region of nothingness or does space have a very intricate structure? then if it is, it follows that every point in space, which it is a subset of must comprise of a structure so that the space will behave accordingly so as to what the point in space behaves.
Forces operating in a dimension? I have zero idea what you mean.
The modern view of forces comes from Quantum Field theory:
https://www.princeton.edu/~achaney/tmve/wiki100k/docs/Quantum_field_theory.html
'In perturbative quantum field theory, the forces between particles are mediated by other particles. The electromagnetic force between two electrons is caused by an exchange of photons. Intermediate vector bosons mediate the weak force and gluons mediate the strong force. There is currently no complete quantum theory of the remaining fundamental force, gravity, but many of the proposed theories postulate the existence of a graviton particle that mediates it. These force-carrying particles are virtual particles and, by definition, cannot be detected while carrying the force, because such detection will imply that the force is not being carried. In addition, the notion of "force mediating particle" comes from perturbation theory, and thus does not make sense in a context of bound states.'
It has a very intricate structure - the vacuum is a very interesting, weird and wonderful thing in Quantum Field Theory.
And general relativity says its dynamical as well - in fact that's the very essence of General Relativity - no prior geometry - meaning geometry itself is dynamical.
And meshing these insights together is one of the greatest challenges of modern physics.
Thanks
Bill
yes general relativity says that space has no geometry but it has structure. so, if space has structure, then the points which comprises space also has structure. although in mathematics the point is only used as a notion to depict a location, it does not mean that a point is non existent.
I'm with Bhobba. I don't know what this means. Honestly I can't really make heads or tails of most of your post.
Each point itself cannot have a structure, but the way they are arranged can be the result of the structure of space.
That's not what it says - it says it has no PRIOR geometry - meaning the space-time geometry (not space - but space-time) is determined by the Einstein Field Equations (EFE's).
Its a very interesting fact of GR that that assumption alone, and a few reasonable physical assumptions, leads to the EFE's.
But this thread is not the place to discuss that - the relativity section is where it belongs.
And Drakkith is correct - points have no structure - they are one of the concepts used in defining what a geometry is. Specifically in GR the geometry is known as a Pseudo Riemannian geometry - but that is just by the by.
Thanks
Bill
in a way that is correct. because points have zero dimension to begin with. but how is it that matter be created from a point in space and in that point only and not elsewhere?
You seem to be thinking that a point is some sort of physical object. It is not. It is a mathematical construct used in various branches of math, including being one of the building blocks of basic geometry. However, it is possible to have geometry without points: http://en.wikipedia.org/wiki/Noncommutative_geometry
It is important to remember that mathematical concepts do not always apply to the real world, and even when they do, it is only because they happen to be useful in describing reality, not because they are fundamentally true.
Conceptually matter occupies a point in space - it isn't created from a point.
That is both VERY important and VERY true.
Our theories are basically mathematical models.
A point is simply an object in the model.
Thanks
Bill
Matter is not created from a point in space, but at a point in space. I don't mean to be nitpicky, but I want to make sure we don't get confused. Matter is only created at that point because that's where the creation event is happening.
its alright sir drakkith. i only observed that when matter is created at a point in space and not from it, then matter will be created at all points in space resulting in non variability. but in reality, this never happened. it is clearly observed that some regions in space have more matter than in some areas. this also is observed here on Earth thus resulting in the variability in the forms of matter existing in our planet. even in outer space there are some regions which are more dense than other areas. if we make the the second statement into account then variability can exist since matter will be created more massive from one point and less massive on the other in relation to the space that governs both points.
so it leads us to wonder if those points in space are static or not.
i am not describing the interaction of the points but the interaction of the space surrounding both points, assuming that the distance of the points are far enough to be observed.
By definition a point is static.
And the variability of the density of matter has a lot to do with gravitational clumping - meaning tiny variations in density get magnified over time by gravitational attraction.
It is believed the universe started out fairly homogeneous.
Thanks
Bill
The reason that matter is clumped together has two major causes:
1. Gravity pulls matter together, resulting in large clumps that lead to the formation of galaxies, stars, planets, etc.
2. In the very early universe, quantum fluctuations led to certain regions of space being more or less dense than others. The matter in areas of space that were more dense tended to coalesce under gravity to form the first galaxies, while the areas that were less dense tended to have matter pulled from them, forming large voids. Without these fluctuations, the early universe would have been totally homogenous and gravity would not have been able to pull matter together since the force would have been equal in all directions.
sir bhobba i mean that the very space itself surrounding the two points must have influence and not just on the points themselves ... this in aggreement on julian barboun's work that tells us space is dynamic. for example, if we put two planets with the same distance to each other in a static space (since a point by definition is static and space is a region of points), then no orbiting or spinning on its own axis (i.e. movement or activity) will not take place no matter how massive the object is. But if the two planets are put into a dynamic space (thus comprising of dynamic points) the space reacts to the objects by conforming in respect to their masses.
assuming that we don't know about gravity, only the objects and the space between it, it can only be deduced that in order for the objects to have activity, the space between the objects must be capable of transmitting the activity produced by the object.
and if that space is filled with points, then those points must be also capable to transmit the activity. so a dynamic space is not comprised of a static point.
Points transmit activity - you lost me.
Thanks
Bill
i am only saying that in order to have a dynamic space, a space that responds to objects, the points that comprises space must also be dynamic. there would be a antithesis if in a dynamic space, it comprises of static points. if it does, space surrounding massive objects would have not been curved.
so how do points in a dynamic space behave?
it is said that space curves on massive objects (relating to relativity) thus it is implied that space changes with respect to mass. so if points are by definition are what comprises space and space changes with respect to mass, then points must be changing to order to define that space changes.
if we are to declare that points within a space is static then space itself is static, hence there should be no interaction between objects within that space as it would forbade it to do so.
but objects in the universe interact with one another, and it is the result of the space that allows the objects within it to do so would you aggree?
I think it's more accurate to say that the relative position of any two points changes, not that the points themselves change.
I think that's a very vague statement that doesn't say much, and I wouldn't try to infer too much from it.
General relativity is a 4-dimensional theory. Each point of the base manifold is a space time event, and not merely a point in space. Points in space time do not move around, they correspond to one particular event (e.g. a light flashes). All you can do is relabel the points if you so choose (make a coordinate transformation). Massive objects curve space time, not just space (and indeed the notion of "just space" is more subtle in general relativity than you have so far conceptualized in your posts). The curvature is already there and there's no "space is changing with respect to mass", there's just "space time is curvED with respect to mass".
Of course, this disconnect can happen when we learn about general relativity. We are used to a 3 dimensional world evolving in time, we are not used to thinking 4 dimensionally. As such, our language is specifically adapted in terms of past present and future, and it becomes semantically hard to talk in a 4-dimensinal manner.
now we are including time but how does time behave in a point in space sir matterwave. if we are then to measure spacetime where x=0, y=0, z=0 is it true that time(t) is also zero?
