Can a man made fire be visible a few miles in the night?
  • Thread starter Thread starter test_new_sw
    Fire
A man-made fire can be visible from a few miles at night, depending on factors such as fire size, atmospheric conditions, and background light. To achieve visibility, a fire would need to produce a luminous intensity of approximately 300-500 candelas. A small fire, such as one on a plate of camphor, may not generate enough intensity, while a larger fire could meet the requirements. Visibility also relies on clear air quality and an unobstructed line of sight. The discussion emphasizes the need for controlled conditions and potential experimentation to determine the exact parameters for visibility.
test_new_sw
Can a fire say in a dish plate with a pile camphor be visible from a couple of miles in the night? What would it take to put a fire visible from a few miles? Will a pile of camphor in 1mx1m do the trick? Been puzzled with this question for a while and thought the experts in this forum can help guide me in the right direction.
The main objective being it (the fire) should be visible to "naked human eyes" at night from a few miles? Can this be achieved? Will a plate of camphor do the trick or will you go for a more conservative 1mx1m fire or even bigger?
Just blow something up, that'll be visible
It should be a controlled fire rather than blowing something up.
Attributes shown by the fire:
1. It happens quickly and is controlled - does not result in forest fire or visible smokes
2. The fire blinks (appears/disappears) three times or gives the illusion
3. Remember the fire is watched from a distance of a few miles
Key questions:
1. Can a small/controlled fire be visible from a few miles at night?
2. If so, what should be the magnitude of the fire?
3. If some one asks you to create one, how will you pull this off?
This phenomenon occurs yearly in India. Any idea to explain this would be very helpful.
Fires can (sometimes) be seen from space, so the answer is 'yes'. In order to calculate how big a fire should be, you need to know the capabilities of the detector (for example, the noise equivalent power, or noise floor), the collection area of the detector, and how much light is given off by a fire- something that will depend on a lot of variables, including what waveband your detector operates at. A single candle has an intensity (W/sr) of about one Candela, so using that, the detector characteristics, and assuming the fire radiates as a point source, you can at least estimate the number of candles needed to be detected a certain distance away.
Thanks for the details.
There are no concrete measurements for this phenomenon. The main objective being it (the fire) should be visible to "naked human eyes" at night from a few miles? Can this be achieved? Will a plate of camphor do the trick or will you go for a more conservative 1mx1m fire?
Think about it. You can see the lights on airplanes that are 5 miles high at night. Or, if you are in the plane, you can see car lights and street lights. The human eye is incredibly sensitive to light in the dark, and the atmosphere is very transparent normally (i.e. no rain, snow, fog, pollution etc.). We see stars that have almost no detectable optical power at all. I'll bet a simple campfire is visible at several miles.
More important than the fire size itself are issues like, air quality/transparency, unobstructed line-of-sight, and amount of background light.
Thanks for the excellent details. Here is a pictorial depiction - * is the place of fire, **viewing point and ~ is just a filler to help with white space mgmt. Both are hill location at least a few thousand feet above the ground and separated by at least a couple of miles.
/ \<- 2 miles-> / \
Is the size/intensity of the fire important? What is the size of a typical campfire? How can the blinking (appearing/disappearing) thrice in a few seconds be simulated?
Been reading a lot on this. From what I have read, it seems the light source should be at least 300-500 cd do to be visible from a few miles. Considering a 100 W incandescent light bulb emits about 120 cd, we need at least 250W - 420W? Is this possible from a fire to match this? If so, using what chemical? Will a campfire have 300-500 cd?
Share your thoughts.
Please help. Thanks
It's difficult to create a reference to judge and it's probably easier to figure this out with a few experiments.
The only idea that comes to mind is to look at the old definition of the unit cd.
One candlepower was the light produced by a pure spermaceti candle weighing one sixth of a pound and burning at a rate of 120 grains per hour.
I can't relate to this defintion personally, but the cd is supposed to roughly correspond to the light of a typical candle. It seems to me you can make a fire that outputs the light of 500 candles. I'm not sure if this would be a small campfire, or larger than that, but it does seem feasible.
Thanks for the details. Is there any way to prove (theoretically) that the light source should be at least 300-500cd to be visible from a couple of miles?
test_new_sw said:
... Is there any way to prove (theoretically) that the light source should be at least 300-500cd to be visible from a couple of miles?
I think so. The light intensity is known to decay as distance squared (assuming you are not directing a beam with optical components), and the absorption of the atmosphere can be estimated in the visible band, with assumptions of altitude, humidity and polution. Then the sensitivity of the human eye can be looked up, under the assumption of no background light. It will not really be proof, but it can be considered an estimate based on optimium (or at least good) conditions. This needs to be done with some care in calculating and double checking (use of multiple sources) of experimental data used in the calculations.
Thanks so much for the time and information. Really appreciate the help on this.
AFAIK it's something like "Vision Threshold: A single candle flame from 30 miles on a dark, clear night". Sounds about right.
Personally with the naked eye I was able to spot camp fires in the hills over ~10 miles. Greatly depends on the air condition and the light pollution.
IMO Bear Grills will have the best answer...
Based on technical details of beacon lights, 300-500cd light is required to be visible from a couple of miles.
Link: http://en.wikipedia.org/wiki/Aircraft_warning_lights
!The common medium white strobe flashes 40 times in a minute,
!at an intensity of 20,000 candelas for daytime/twilight, and
!2,000 candelas at nighttime.
Is it 10 miles from the foot of the hill where as the campfire was at a suitable elevation?
Can someone share their thoughts on this?
Please share any additional thoughts on this... Thanks
Can someone share their thoughts on this? TIA
Need confirmation on two aspects:
1. Luminous intensity of a fire should be in the range of 500 candela to be visible from a few miles across in the night
2. Can a man-made fire on a plate of camphor produce 500 candela of luminous intensity
Please share your thoughts on the above observations.
12K
10K
