DaveC426913
2025 Award
- 24,698
- 9,108
- TL;DR
- This is for a story and I want to be sure the aerodynamics are plausible. It involves a parasail (briefly) carrying its tow vehicle.
If this is on the wrong forum, apologies. This is for a science fiction story, but presumably the physics won't change. It is specifically the aeronautics behavior I'm interested in.
Executive summary: could a sufficiently-large parasailing vehicle be designed to lift its tow vehicle out of the water and carry it for a (short) time?
What I'm envisioning is
- tow vehicle torpedoing just under the surface, towing the glider behind it many dozens of metres in the air (or a hundred?)
- pilot reels in cable while pitching up, so that the glider pulls forward until it is almost vertically on top on the tow vehicle (you can do this with a kite)
- pilot commands tow vehicle to breach - porpoising out of the water
- tow vehicle dangles from cable while glider carries it (on a slow descent) until tow vehicle touchs down again
This is effectively what windsurfers do:
The difference in my setup is that the airborne payload is much more than just a parachute - it's a winged frame with pilot. This raises a key question of weight ratios between tow vehicle and pilot vehicle. The tow vehicle must be powerful enough to control the pilot vehicle with ease but not so heavy as to not be carryable by the pilot vehicle.
Is it too much to hope for some amount of forward motion and some glide-ratio?
Oh. Also, full disclosure: the tow vehicle is a critter - like a giant manta ray. That shouldn't change the physics, but it does shed some clarity on my diagram:
- Payload: Lightweight frame with huge glider-like wings. Call it maybe a couple hundred pounds with pilot.
- Tow-vehicle: Rather than a surface boat, it's a submarine drone (gets better purchase on the water, has more freedom of movement). Is as large and powerful as necessary to tow payload, but not so heavy as to negate any chance of glider carrying it.
- Connected by cable of variable length, can be reeled in or eased as desired
