Can a Pendulum Clock Function Independently of Gravity and Temperature Changes?
Gavroy
Hey
I asked myself whether there are any possibilities to construct a pendulum clock, which period is independent of the acceleration of gravity, which may differ at different places, or the extension of the pendulum lenght, that is caused by different temperatures?
And? What answer did you give yourself?
well I have not a clue..that is why I want to ask you...
Well, the force of gravity and the length of the arm are pretty much the things that define the period of a pendulum, so if you are were hoping to build a clock without those things being constant, it pretty much couldn't use a pendulum.
Since those are things that a pendulum has as its weaknesses, why would you use a pendulum at all, instead of using an alternate method that is not susceptible to the very things that you plan to vary?
Gavroy said:
Hey
Have you looked into the clocks designed in the mid to late 1700's by http://www.nmm.ac.uk/harrison" ?
Hi-
but the point is: do you want to have an idea on how to overcome to acc. gravity or thermal change on the value square_root(g/L) or what?
