Can a single quark exist in isolation ?
In summary, it is believed that a single quark cannot exist in isolation because of its net "color charge" and the strong force which increases with distance. This results in the quark always being bound to other quarks and the creation of more quarks when attempting to separate them. This phenomenon is known as confinement or infrared slavery, and is a consequence of asymptotic freedom, which is the weakening of the coupling between matter and the gauge field at high momenta/small distances. The bag model of confinement is now superseded by a linearly rising potential at large distances.
wolram
Dearly Missed
4,446
558
As I understand it, a free quark can't exist because it has a net "color charge" (red, green, blue, antired, antigreen, or antiblue). Much like systems of electric charges tend to arrange themselves to become chargeless on large scales, systems of quarks tend to arrange themselves to be "colorless" in composite particles (like mesons and baryons). A big difference between this and electromagnetic forces, however, is that the effective "strong force" increases with distance, so a quark couldn't escape the pull of its colored partners as a planet could the solar system. In fact, if you try give a quark energy to make such an escape (as in a decay or collision), the potential energy built up between quark pairs will tend to lead to the creation of more quarks -- a quark jet.
Hi ST, this, " strong force" increase with distance has me baffled, quite easy,
but what is the mechanics behind this ?
Well, ST, really told you the very essence of the story. Quarks have a net color. Every net color will interact with another colour to become colourless. So if you look at quarks in their most stable state (ie the ground state energy) , the most stable configuration is the colourless quark combination. So, this combination is most likely to occur. Now, suppose you want to take out one quark and separate it from its original structure. While doing so, the interaction between this quark and it's "collegues" in the colourless combination will increase (this is what asymptotic freedom is all about). The increase in energy will be used for the creation of other quarks. This happens because nature is as lazy as possible : The potential energy from the interaction is converted "automatically" into new quarkpairs...
regards
marlon
Thankyou, Marlon. seem to me nature is very busy, i will read up asysptotic freedom.
This is called "infra-red slavery". "Asymptotic freedom" is something else.
Asymptotic freedom is the weakening of the coupling between matter and the gauge field at high momenta/small distances.
Asymptotic freedom would be a bit of an odd name for the increase in the strong force with distance.
First of all, if the strong force coupling constant rises when distance rises than it must lower when distance lowers, so what is your problem ? I never claimed to give the exact definition of asymptotic freedom ("free" quarks at "very" short distances, etc etc), but i wanted to illustrate the consequence of a negative beta function. So what are you objecting against ?
Secondly, the strong force is not about the interaction between matter and gauge fields but about matter-matter interactions mediated by gauge fields. So knowing this, tell me where i went wrong. Another thing, do you even know how the strength of the strong force is expressed in terms of matter and gauge fields ?
The definition of asymptotic freedom is quite http://nobelprize.org/physics/laureates/2004/gross-slides.pdf. At least i hope so, otherwise i have to rewrite my master's thesis:uhh:
TO the OP : check here for more info on asymptotic freedom
No, because, we believe :confused: , the potential energy between quark and antiquark increases with separation [V(r)~ar]. So quarks and gluons can never escape from the colour singlet states (observable particles i.e colourless hadrons). We call this confinement or infrared slavery.
regards
sam
You are right, the QCD "running coupling constant" decreases with increasing q^2 (the momentum transfer) and therefore becomes small for short-distance interactions i.e the coloured particles (quarks and gluons) behave as if they are free. We say that QCD is "asymptotically free".
Yes, confinement(large distance behaviour) is the name :smile:.
regards
sam
You called confinement (or infrared slavery) asymptotic freedom.
Admit a careless mistake, and move on.
Then, get to it, if you have that mistake in it.
QUOTE]
Also, the bag model of confinement is unrelated to AF, but is a now superseded mode of confinement. A linearly rising potential at large r is more popular.
Websites are not answers.
Perhaps I'm missing something, because I don't see why the distinction is so important for what marlon said. Doesn't "infrared slavery" refer to the divergence of the strong interaction at large distance/small energy, while "asymptotic freedom" refers to the behavior at small distance/large energy? I agree that confinement (that is, the lack of free quarks) is more directly due to infrared slavery, but in the context of marlon's post, it seems either would do:
He's just talking about the interaction strength increasing with distance, which I believe is true in any limit for the strong force -- it wouldn't necessarily have to refer to confinement.
He answered the question correctly but named his answer incorrectly :wink:
Asymptotic freedom is the success story of QCD.
The hypothesis of Quark confinement and its extension "coloure confinement" are an embarressment. As to date no proof exists.
To explain quark confinement various suggestion have been made. The most popular one is to assume a linear potential between a quark and an antiquark at large distances, so that there will be only bound states for the pair.The same picture also shows up in the lattice gauge theory of Wilson, who formulated the condition of "quark" confinement in terms of his loop and showed that it is satisfied in the strong coupling approximation. However, it is extremely difficult to formulate the condition for confinement of gluons, which are also coloured, in the lattice gauge theory.
Eventhough I am not an expert on QCD, I did some work on the "mathematical" problem of coloure confinement based on BRS-algebra.
The idea (originally due to Nishijima) based on an analogy with QED.
Bassically, we let the quarks and gluons have the same fate the scalar and longitudinal photons have in QED.
regards
sam
No, i did not.
Now, YOU are naming things incorrectly. The linear potential is not just assumed, it follows from the model you are using. To give you an example : the dual abelian Higgs model [1] will predict the mentioned linear potential without it "being assumed". The basic idea behind this model is to use the theoretical concept of magnetic dipoles. In low energy QCD the coupling constant is very big. Suppose we are able to make a transformation into a "world" where the transformed coupling constant is small, this would be very good since perturbationtheory can still be used in infra red QCD. The transformation i am talking about is the one defined by replacing the E fields by the B fields. So quarks become magnetic monopoles and gluons become dual (electrical) gauge pairs.
[1] The Mechanism of Quark Confinement : http://arxiv.org/abs/hep-ph/9809351
marlon
marlon said:
No, i did not.
1) Asymptotic freedom can not explain our inability to observe coloured particles.
2) Free inside Hadrons does not mean or imply "cann't be free outside Hadrons"
So you are wrong.
READ my post carefully. Didn't I say that the linear potential "shows up" in Wilson's lattice gauge theory?
magnetic dipoles? I thought it is monopoles! NAMING THINGS INCORECTLY. You have done it again.
Yes, some modles do derive the linear potential. However, almost all modles make some alternative assumptions in order to derive that form of potential. The model you mentioned (magnetic confinement of quarks [1]-[4]) makes the (rather strange) assumption that gluons do not participate in long range interactions.This is the so-called Abilean dominance cojecture which is necessary for the derivation of the linear potential.
Other crippling features of this model are;
1) QCD coloure group SU(3) is not identical to an "Abilean" Higgs. One can show that Abilean-projection-SU(2) and SU(2) have different behaviour in the ultraviolet region.
2) QCD Lagrangian is based on the exact (unbroken) local group SU(3). So scalar fields are absent and the "superconductor" analogy seems inappropriate.
3) The posibility that quarks carry "magnetic" charge does not mesh well with Asymptotic Freedom.
4) One can not get rid of the unwanted neutral contribution to Wilson loop.
5) Abilean gauge fixing (i.e making QCD an interaction theory of photons, monopoles and matter{quarks & gluons}) requires monopole dominance as well as Abilean dominance conjectures.
6) Lattice gauge theory calculations show that "Abilean dominance" is not universal.
HAVE FUN
sam
[1] Nielsen,H.& Olesen,P.(1973), Nuc. Phys.,B61,45.
[2]Englert,F.(1977). "Electric and magnetic confinement" Lectures given at the Cargese Summer School.
[3]Marciano,W.& Pagels,H.(1978), Phys. Rep. 36C, 3, 137.
[4]Mandelstam,S.(1975), Phys. Rep.23C, 3, 245.
So you are wrong.
I never said any of this. Please read my posts more carefully prior to reacting in this way.
My reaction was to the fact that you stated "the linear potential is assumed..." I never referred to this particular model.
Yep indeed magnetic monopoles. I made a mistake there.
Anyhow, i still argue this business about infra red slavery versus asymptotic freedom. Up till now, you did not show me, apart from some superfluous remarks, where i went wrong. This is not about me not wanting to admit to a mistake. I just don't see where i went wrong. If it is that easy to show me, than why do you need so many lines and references to prove me wrong ?
This is not the same as saying that the linear potential itself is assumed from the beginning (which is what you stated, but i am sure you are going to deny this).
Nope, this is NOT the basic assumption. I explained to you what that was. Read the reference, please.
Err, your point being ?
Why this summation ? Did i ever say this model was completely correct ? Again, read the paper before reacting.
HAVE FUN
No problemomarlon
Marlon, you amaze me again, with you knowledge, comprehension, and ability to talk to people about it.
Aglkasjg! HE WAS MOZART!Anyway, what also amazes me is how much we know about quarks. It seems a bit silly actually. There are tiny little particles that make up what we thought were elementary, with strange triangular kind of formations, stuck together with glue, and they come in different flavors! Flavors include personalities— they can be quite charming, and even some have nice derrières. They are of many different colors, red, green, blue, and even anti-red, anti-green, and anti-blue! They enjoy spinning. What experimental proof is there of quarks? Have we "seen" them? Or is it that there is just missing energy, or what?
Hey
We sure have :)
marlon
Umm, Marlon, "they are seen as the 'elementary particles'" is not really a fair answer to MK's question, "Have we seen them ?(quarks)". We have inferred quarks from such things as scaling behavior, and I guess you could say we have "seen" partons. But seeing QUARKS?
We see jets. It is not easy to justify the jets if it is not because of subcomponents of the hadrons, and these jets are near of quarks than of partons.
You were misled, what you really need to look up is quarks confinement not asyptotic freedom.
regards
sam
regards
sam
Nope he was not, as has been explained in several posts now from ST, me and others. The only incorrect information i read in this thread is some superfluous stuff on "assumed linear potentials". Just drop this rediculous crusade and go on, please.
regards
marlon
1. What is a quark and can it exist in isolation?
A quark is a fundamental particle that makes up protons and neutrons. According to the theory of quantum chromodynamics, a single quark cannot exist in isolation due to its strong interaction with other particles.
2. Why can't a single quark exist in isolation?
Quarks have a property called color charge, which allows them to interact with other quarks through the strong force. This means that quarks are always found in groups or bound in composite particles such as protons and neutrons.
3. Has a single quark ever been observed in isolation?
No, a single quark has never been observed in isolation. Whenever scientists try to isolate a quark, it creates a new quark-antiquark pair, making it impossible to observe a single quark.
4. What is the importance of understanding quarks and their interactions?
Understanding quarks and their interactions is crucial for understanding the behavior of matter at the subatomic level. It also helps us understand how the universe evolved after the Big Bang and how particles and matter interact with each other.
5. Could there be any exceptions to the rule that a single quark can't exist in isolation?
There are some theories, such as quark confinement and quark-gluon plasma, that suggest that under extreme conditions, such as in the early universe or in high-energy collisions, a single quark could briefly exist in isolation. However, this has not been observed or confirmed experimentally.
  • High Energy, Nuclear, Particle Physics
