Can anyone help with eigenfunction?
  • Context: Graduate
  • Thread starter Thread starter samleemc
    Eigenfunction
The discussion revolves around solving a second-order linear ordinary differential equation (ODE) of the form y'' - 2y' + y = ky, where k is an eigenvalue. Participants seek to find the corresponding eigenvalues and eigenfunctions under the boundary conditions y(0) = 0 and y(π) = 0 for 0 < x < π.
  • One participant presents the ODE and requests help in finding eigenvalues and eigenfunctions.
  • Another participant suggests solving the ODE by treating k as a parameter and reformulating it as y'' - 2y' + (1-k)y = 0.
  • Several participants derive the characteristic equation and discuss the roots, indicating that k must be negative for m to be imaginary.
  • There is a proposal that the general solution can be expressed in terms of sine and cosine functions, leading to conditions for eigenvalues based on integer values of n.
  • One participant questions whether k could be zero, seeking clarification on the implications of k needing to be negative and n needing to be an integer.
  • Another participant concludes that k must be the negative square of an integer to serve as an eigenvalue.
Participants express differing views on the implications of k being negative and whether k can equal zero. The discussion remains unresolved regarding the specific values of k that qualify as eigenvalues.
There are unresolved assumptions regarding the nature of k and its relationship to integer values, as well as the implications of the boundary conditions on the solutions.
samleemc
if y''-2y'+y=ky k=eigenvalue, y(0,pi)=0, 0<x<pi
find corresponding eigenvalues and eigenfunctions.
thx a lot!
How would you solve the ode
y''-2y'+(1-k)y=0
Regarding k as a parameter for the moment
I got this
sqrt{k} = m
A(1-m)2 -2A(1-m)+A(1-k)=0
B(1+m)2 -2B(1+m)+B(1-k)=0
and what then !??
Please help! thank you very much!
can anyone help!?
It's a 2nd order linear ODE with constant coefficients.
Trying the solution y=e^mx (as I think you've done) gets your solutions (unless...etc, look it up).
Solve for m, then you have one function that's an eigenfunction, with eigenvalue corresponding to m.
thx a lot!
The characteristic equation for y"- 2y'+ (1- k)y= 0 is [itex]r^2- 2r+ 1-k= 0[/itex] which is the same as [itex]r^2- 2r+ 1= (r- 1)^2= k[/itex] and has roots [itex]r= 1\pm \sqrt{k}= 1\pm m[/itex] with your choice of m as [itex]\sqrt{k}[/itex].
The general solution is [itex]y= Ae^{(1+m)t}+ Be^{(1-m)t}[/itex]
Setting that equal to 0 at x= 0 and [itex]\pi[/itex], we find that as long as 1+ m and 1- m are real, A and B must be 0.
In order for k to be an eigenvalue, k will have to be negative so that m is imaginary. Given that, and writing m= ni, [itex]y= Ae^{(1+ni)t}+ Be^{(1-nit)}= e^t(Ae^{nit}+ Be^{-nit})[/itex]. We can write that as [itex]y= e^t(C cos(nt)+ D sin(nt))[/itex].
Now we have [itex]y(0)= e^0(Ccos(0)+ D sin(0))= C= 0[/itex] and [itex]y(\pi)= e^{\pi}(Ccos(n\pi)+ Bsin(n\pi)= Be^{\pi}sin(n\pi)[/itex] (because C= 0) and that must be equal to 0. That will be true either for B= 0 or for [itex]sin(n\pi)= 0[/itex] which will be the case as long as n is an integer.
Can you find the eigenvalues and eigenvectors from there?
k have to be negative and n have to be integer, do u mean k=0 ?!
Please answer ! Thanks !
k=m2=-n2
Therefore, any k that is a square of an integer (with a minus in front) is an eigenvalue to this problem.
