Can Matter Enter a Black Hole Intact? Debate & Advice
  • Context: High School
  • Thread starter Thread starter MikeeMiracle
    Black hole Hole
The discussion centers on the debate regarding whether matter can enter a black hole intact, specifically addressing the phenomenon of spaghetification. Participants agree that for small black holes, spaghetification occurs near the event horizon, while for larger black holes, it occurs closer to the singularity. The gravitational gradient outside the event horizon is less severe for larger black holes, allowing for the possibility of crossing the event horizon without immediate disintegration. Key insights include the relationship between mass and spacetime curvature, which diminishes as black hole mass increases.
  • Understanding of black hole physics and event horizons
  • Familiarity with the concept of spaghetification
  • Knowledge of spacetime curvature and its mathematical representation
  • Basic principles of general relativity
  • Research the "ouch radius" concept in black hole physics
  • Study the effects of mass on spacetime curvature in general relativity
  • Explore the differences in spaghetification effects between small and large black holes
  • Examine the implications of crossing the event horizon in various mass scenarios
Astronomy enthusiasts, physicists, and anyone interested in the complexities of black hole behavior and the effects of gravity on matter.
MikeeMiracle
TL;DR
Can anything enter a black hole intact
I am having a debate with someone who appears knowledgeable about black holes from the language he is using but we have a disagreement about if matter can enter a black hole. He is trying to tell me the gravitational gradient near the event horizon is such that spaghetification occurs as you approach the event horizon. I am debating that the spaghetification effect occurs near the singularity itself, not the event horizon.
I came to this understanding from reading posts on this forum that spaghetification will occur outside the event horizon for small black hole but for larger black holes the gravitational gradient outside the event horizon is not so great and that it would be possible for a human to cross the event horizon intact and alive.
I may have misinterpreted what I have been reading on here but can anyone offer some advise as to which one of us was correct.
Thanks
Tell your friend to stick to cooking spaghetti, as he knows nothing about physics!
  • Haha
You are correct. You could search for the "ouch radius" at PF for some details.
Note that the radiation environment outside most black holes would fry you anyway...
You are correct. For a small enough hole, "close enough to the singularity" for spaghettification turns out to be at or around the horizon; but as the hole gets larger the "spaghettification point" moves further and further inside the horizon.
A simple heuristic to see the behavior is that the spacetime curvature of a black hole, which has to get sufficiently large for things like spaghettification to occur, is proportional to ##M / r^3##, where ##M## is the mass of the hole. Since at the horizon, ##r = 2M##, the spacetime curvature at the horizon is proportional to ##M / (2M)^3 = 1 / 8 M^2##, i.e., it gets smaller as ##M## gets larger.
Your friend is wrong. For a sufficiently large black hole - not only would you be able to cross the event horizon without deleterious effects on your personage - but it is so abstract a surface that you would have trouble detecting that you had crossed it at all - you'd have to calculate the location of the event horizon (using mass and distance measurements) to conclude you were passing through it.
Thank you for the responses. He seemed to be obsessing over the escape velocity at the event horizon being the speed of light to which I was responding that just because the escape velocity is the speed of light that does not mean you need to travel at the speed of light to fall into a black hole which kicked off this debate. His response was:
"What I stated is that no positive mass density object can even reach a black hole. And what I further stated is that objects are attracted and/or pulled into the event horizon at or near the speed of light. And due to being drawn into a higher rate of acceleration, they disintegrate because there is a limit to what compounds can do to support their constituent structural integrity at a molecular and atomic level before they just fail. It is also called nuclear decay. So you are not trying to travel at the speed of light [which is impossible], you are being drawn into the gravitational current that is racing at the speed of light."
The above to me seems like he is not taking into account the IRF of the falling object and instead looking at the falling object as an observer to reach that conclusion.
As ever I am greatful to have this forum as a resource to cross check my understanding.
Wrong.
No. In any local frame the event horizon passes through you at the speed of light. This does not give any meaning to the notion that you pass through the event horizon at the speed of light.
The rest seems to be nonsense.
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 46 ·
  • · Replies 22 ·
  • · Replies 73 ·
  • · Replies 51 ·
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 29 ·
