Can compressing air behind a bullet increase muzzle velocity?
  • Thread starter Thread starter sid_galt
    Efficiency Gun
7 replies · 6K views
sid_galt
If the gunpowder in a gun is detonated in a chamber consisting of compressed air such that the top of the chamber is formed by the bullet, wouldn't the efficiency of energy extraction from the gunpowder increase as the pressure ratio will be much higher? Would such a bullet be able to achieve much higher velocities?
Hi sidgalt!
To say the truth I have no idea about ballistics. Anyway, I thought you will find interesting this link:
http://www.aa.washington.edu/AERP/ramac/
It's great. Try to look into it and post a comment here if you want.
The pressure generated by the burning propellant is orders of magnitude higher than you could provide with any reasonably-sized pump, so it really would help much to add that tiny bit of energy.
Clausius2 said:
Hi sidgalt!
Thanks for the link Clausius2. It's fantastic. I had no idea they were using ramjets to power projectiles.
Assuming detonation gives a pressure ratio of 18:1, the theoretical efficiency is 68%. If we compress the air beforehand to a pressure of say 4:1, then the theoretical efficiency rises to 81%, a 13% difference. I would say it's quite a lot. Of course the casing would also have to be 4 times thicker and a method of injecting gunpowder pellets will have to be arranged.
It was off the head. I did a google search but I coudln't find the compression ratio generated in a gun
It's about 50,000 atmospheres. Good luck trying to compete with that
using a pump.
Or you could do it the simpler way... more powder and a longer barrel...
Cheers...
