Can Electromagnets Achieve Levitation?
  • Context: High School
  • Thread starter Thread starter thebluser
7 replies · 2K views
thebluser
so let's say that i take and electromagnet and a magnet. i connect them to a position where if i turn on the power they will repel each other(the magnet is on top and is connected to the bottom electromagnet). my question: will it levitate when i switch the power on and increasing and deacreasing the flow to the electromagnet? imagine that there's enough electricity flowing to the electromagnet to repel the whole device weight. I am not sure youll understand this question but if you dont, its okay :p.
because i don't have the materials.
well its very cheap and easy to make an electro moagnet
... say 100ft of 20swg of enamelled copper wire, a piece of iron for the core say 4 inches long and 1 inch diameter approx ( not critical) and a power supply that can supply say ~ 12VDC at ~ 5Amps max
and many hobby shops will sell permanent magnets
Dave
You will need to secure the levitating magnet or electromagnet to a pole to keep it in a stable position, but yes it will levitate if the magnets are strong enough. You can do this experiment with 2 permanent magnets that are ring shaped. Stick them onto a rod or something that will hold them in position with like sides facing each other. Cheap and easy.
Using the Google search terms “science projects magnetic levitation” I found many sites describing such projects. Some are complicated, some are simple, but all of them illustrate the phenomenon of magnetic levitation. Here are just two to get you started:
http://www.paksc.org/pk/science-experiments/physics-experiments/item/792-magnetic-levitation-science-project.html
http://www.levitationfun.com/
thank you all for your very good answers :)
