Can HNO3 and CH3COONa act as a buffer solution?
  • Thread starter Thread starter zorro
    Buffer Rules
7 replies · 9K views
zorro
I read somewhere that HNO3 and CH3COONa can act as a buffer solution. I know that the following solutions can act as a buffer-
1) A solution of weak acid and its salt with a strong base.
2) A solution of strong base and its salt with a strong acid.
3) A solution of a salt of weak acid and a weak base.
The above two compounds don't fit in any of these criteria.
How can they act as a buffer?
Chemistry news on Phys.org
Try to think about it. What compounds/ions are in solution? What are the equilibrium reactions?
HNO3 + CH3COONa -------> NaNO3 + CH3COOH
Here we have a mixture of salt of a strong acid and strong base and a weak acid on the product side.
So do you mean CH3COOH and CH3COONa (at equilibrium) are responsible for buffer here? What about NaNO3 and HNO3? Do they play any role? Give reason for your answer.
Agreed - that will be mixture of acetic acid and sodium acetate.
Like mixture of NaON and NaCl? It is not a classic buffer. Relatively concentrated solutions of strong bases or strong acids do resist pH changes, so in a way they are similar to buffers, but they don't require presence of salts.
Like solution of ammonium acetate? Buffering capacity close to zero, much lower than in both earlier cases.
What happens if you mix - say - 2 moles of sodium acetate, with 1 mole of nitric acid?
Edit: I see you were on the right track already. Think about composition of the solution after the reaction. Does it contain nitric acid?
HNO3 would be completely consumed and 1 mole of sodium acetate would remain as a reactant.
1 mole each of NaNO3 and CH3COOH are present in product side.
So here CH3COOH and CH3COONa form a buffer solution.
But we still have 1 mole of NaNO3. Will it not affect the buffer?
What kind of acid is nitric acid? Will this kind of acid make a buffer?
No, it just changes ionic strength of the solution.
