Can I mix these 3 chemicals together?
  • Thread starter Thread starter n0_3sc
    Chemicals
The discussion confirms that mixing pure Benzene, Toluene, and Cyclohexane in a cuvette is safe under ambient conditions, as these hydrocarbons do not react with each other. They are all miscible in any proportion, forming a blend without any chemical reaction. However, caution is advised due to the volatility and flammability of these substances, particularly Benzene, which is a known carcinogen. It is recommended to conduct spectral analysis of each compound individually before mixing to understand the effects of solvent interactions on the spectra.
  • Understanding of hydrocarbon properties and behavior
  • Familiarity with spectroscopic techniques, particularly FTIR and NMR
  • Knowledge of Material Safety Data Sheets (MSDS) and chemical safety
  • Basic laboratory safety protocols for handling flammable and toxic substances
  • Research the effects of solvent interactions on spectral analysis
  • Study the MSDS for Benzene, Toluene, and Cyclohexane
  • Learn about the safety measures for handling volatile organic compounds (VOCs)
  • Explore the principles of mixing solvents in organic chemistry
Chemists, laboratory technicians, and anyone involved in spectroscopic analysis or handling organic solvents will benefit from this discussion.
n0_3sc
Can I mix these 3 chemicals together??
I'm not a chemist so don't laugh at my lack of knowledge:
I want to mix pure Benzene, Toluene and Cyclohexane into a single Cuvette. Is this alright? I'm not going to produce any harmful gases or weapons of mass destruction?
Thanks.
Chemistry news on Phys.org
I don't see any possible way for those chemicals to react to any favorable degree, then again, I may be wrong.
I actually need it to test out this spectroscopic source I built. I want to see if it can distinguish each spectra when the chemicals are mixed.
Just need to make sure I'm not going to be on a Most Wanted list tomorrow...
Those are just hydrocarbons, and of only Carbon and Hydrogen. One would not expect any reaction. A good plan is to first see the spectrum of each compound by itself before making the mixture.
Thanks. I've already seen the spectrums of each compound. :biggrin:
just don't light it on fire.
I won't, but the laser propagating through it just might.
Except chemical spectra are altered by solvents - the non-chemical, electric interactions between your different species mean that the spectra of the sum is not just the sum of the spectra. This is why you always specify your solvent - for example, FTIR in methanol, FTIR in gas phase, NMR in CDCl3 with TMS reference, and so forth.
There is no harm in mixing these hydrocarbons, they will not react under ambient conditions. Be warned that they are volatile, flammable, and benzene is a known carcinogen.
They are all miscible in all proportions and will simply form a blend, no reaction will occur. Benzene is indeed carcinogenic, toluene is also toxic by inhalation. MSDS's for all three are available in public doman, just Google "MSDS Benzene" etc.
Are some materials' MSDSs copyrighted and not legally available?
Well, some materials' MSDS's will only be available from the company that manufactures them, whereas common commodity materials MSDS are freely available. Thats the point I was making.
All solvents used in basic O-chem lab. I would recommend a nice hood breathing a lot of benzene or toluene isn't so good for you and they are all flammable but not going to explode or melt threw a test tube or really interact with each other in much of a serious way at all.
If you mix together toluene, cyclohexane and benzene they will basically just mix. Thats it. Nothing else will happen.
  • · Replies 19 ·
9K
  • · Replies 43 ·
14K
