Can matter form a black hole while falling toward a singularity?
  • Level: Undergrad
  • Thread starter Thread starter Grasshopper
    Black hole Hole
114 replies · 13K views
"Not a force" is a quibble. If you prefer, call it acceleration.
Let me rephrase. I am orbiting at 3+ε R. The dust gets closer, the horizon moves out,and now I am at 3 - ε R and my orbit is now unstable. How does it know? I know because if I make a small perturbation, it is no longer restored. The restoring force acceleration is now in the opposite direction. But as you say, there's no way of telling that this has happened before light from the dust has reached me.
Since I was talking about orbit stability, replace 3 with 6.
To be clear: you mean just a little outside the innermost stable timelike circular orbit at ##r = 6M## (3 times the Schwarzschild radius), correct?
You will see the change in your orbital parameters when the dust falls past you. That will most likely be way before the horizon moves out. You won't be able to detect any change in the horizon from the behavior of your orbit.
The way your orbit "knows" that its parameters have changed is that the dust fell past you. It has nothing to do with the horizon.
You know because your orbital parameters have changed and you can now compute that your orbital radius is slightly less than ##6M_2## (where it was slightly greater than ##6 M_1##). Note that, in order to maintain a circular orbit as the shell falls past you so that you can detect the change in your orbital parameters, you have to use rocket thrust. If you don't, you won't be in a circular orbit any more; you'll be in an unstable elliptical orbit (which, I suppose, would be another way of detecting the change as the shell fell past you).
Once you are in your new circular orbit with changed parameters, you can tell that it's unstable by seeing what happens when small perturbations occur, yes.
For an inward perturbation, yes. For an outward one, it actually isn't.
One could imagine a whole galaxy with millions of black holes collapsing inside its Schwarzschild radius.
Although, technically speaking, there is, classically, one global event horizon and a future spacelike singularity (as already mentioned), and r= constant hypersurfaces inside the Schwarzschild radius of this hypothetical galaxy are spacelike, for an observer that's free falling (along with every other star etc ) inside, these individual "black holes" -that have only apparent horizons- are still there, aren't they?
The situation is reminiscent of a closed FLRW spacetime, with the crucial difference that in the FLRW case there is no exterior region, or horizon.!
Also, in the Oppenheimer/ Snyder pressureless dust collapse model, one could imagine that these specs of dust are, themselves, collapsing objects with their apparent horizons, and they all have a common global event horizon and a common future spacelike singularity.
There are also collapsing models where timelike singularities ( with their corresponding Cauchy horizons), are formed before the final spacelike singularity.
By the way, one can also have black holes "inside" other bhs in the cases of Bag of gold or Baby universe spacetimes.
These are not related, of course, with Grasshopper's question, but i think they're worth mentioning.
There can be multiple apparent horizons inside a single event horizon, yes.
Not really, since there are no horizons at all in a closed collapsing FRW spacetime.
No, you can't, because in the O-S model the "dust" is continuous; it's not individual "specks" separated by vacuum, it's a single continuous region occupied by matter. "Dust" is a technical term in models like this and should not be interpreted literally.
Can you give an example? If you are thinking of Kerr spacetime, no, there are no models similar to the O-S model for Kerr spacetime. Also, the presence of the Cauchy horizon at the inner horizon of Kerr spacetime makes most physicists believe that the region approaching and inside that horizon, which is the region where the timelike singularity is, is not physically reasonable and would not be expected to be present in a realistic model.
The "bag of gold" model is simply a carefully chosen profile of matter inside the event horizon that causes additional apparent horizons to be present. So this is not an example of multiple event horizons.
The "baby universe" spacetime, AFAIK, is speculative only; nobody has ever actually produced a consistent model of it.
Thank you for the answer!
I don't really disagree with most of the replies you gave in this thread, but i think that you're using a very restricted definition for a black hole spacetime.
a)In a closed, recollapsing universe ( like the k=1FLRW model), there is no future null infinity/ asymptotic flatness, so the "classic" definition of a black hole is not applicable. Yet, bhs can exist in such spacetimes.
The "problem" seems to be the notion of the Absolute Event Horizon.
By the way, in my 1st post I stressed the fact that the closed FLRW universes that end in a big crunch have the obvious difference that they have no exterior region or an event horizon !
b) About the OS model: One can consider it as a gluing of a FLRW region and a Schwarzschild exterior.
As in the case of a realistic model of a universe, the specs I was referred to is only an approximation, when you have a big number of them and they're approximately homogeneous.
The hypothetical example of a collapsing galaxy is not the same, of course, but it's related: If a whole region with lots of millions of black holes and lots of stars and other stuff collapses, for some time, an observer that falls freely inside could see other "individual" black holes inside this collapsing region! He could also jump inside one of them!
You're right that technically only one black hole is properly defined in that case, but l think that's a bit of nitpicking. Technically, our own galaxy's central Sagittarius A* supermassive black hole and Andromeda's one (and, possibly, lots of other smaller bhs that'll merge with them) are not "distinct" holes, because they share, probably, the same Event Horizon, after all!
I'm using the definition that is the standard one in the GR literature. If you want to use a different definition, you should at least make clear what definition you are using. For example, if you want to use "black hole" to mean "apparent horizon and region inside it", then you should say so. And you should be prepared to deal with the limitations of that definition--for example, an apparent horizon is frame-dependent whereas an event horizon is not.
Please give a reference for this claim.
Only if they end up merging.
Concerning your fourth objection: No, I was not thinking about Kerr. In the unperturbed, eternal Kerr spacetime only timelike singularities could exist (mathematically). And its well known, as you already pointed out, that due to blueshift/ mass inflation instabilities, instead of cauchy horizons, most probably null or spacelike singularities are happening there.
I had in mind some models of inhomogeneous collapse, where, temporarily, timelike singularities are developing, but the final endpoint of the collapse is a spacelike one, so there are both a Cauchy and an event horizon. I think Joshi described such models.
About bag of gold spacetimes:
An example is the gluing of a closed FLRW universe and a black hole spacetime, so my comment is similar to the previous ones.
As for the Baby Universe scenarios: I don't really think that all these models (e.g Frolov/ Novikov)are inconsistent.
They just need some underlying assumptions as every other model. Maybe you could call them controversial.
If you can find a reference, that would be helpful. These models sound interesting but I'm not familiar with them.
Please give a reference. The only such model I'm aware of is the Oppenheimer-Snyder model, which is not a "bag of gold" spacetime as I understand that term.
Again, please give a reference. We need some specific models as a basis for discussion.
The collapse of a closed FLRW universe is very similar, in fact, with a merging of lots of individual black holes in a realistic case!
As for a reference: Roger Penrose's lectures about cosmology, gravitational entropy etc.(there are lots of them).
About the coalescence of S A* with Andromeda's supermassive bh: Come on, it's more than obvious that I was hypothesizing about a future merging!
I'll search for references, maybe tomorrow. I have a lot of work to do now!
Anyway, thanks for the intriguing conversation.
No, it isn't, because, as I have already commented, there are no event horizons in a closed collapsing FRW universe. The only similarity is that the interior of the Oppenheimer-Snyder solution is a portion of a closed collapsing FRW universe, but that is a collapse of one black hole, not multiple black holes merging.
We need a specific reference, not a vague gesture in the direction of "lots of them".
If you're hypothesizing, you should make the hypothesis clear: for example, "If the two holes merge in the future, they will share a single singularity". Don't assume that what is "more than obvious" to you--because you are the one thinking up the scenario--will be obvious to others.
Your comment about the possible future merging of the supermassive black holes is not at all relevant to the point I've made! It's totally irrelevant if these holes will actually merge or not.
It is possible that such a thing will happen, and that's enough!
The point is that when everybody today uses the term "black hole", he/she's not referring necessarily to the definition that you have in mind.
This well known definition presupposes the notion of future null infinity etc (actually I've already mention that), so it's suitable for rigorous mathematical proofs, but not for complicated situations.
It is well known that there is no strict definition for a black hole that could be applied everywhere:
A Kerr/ Ads spacetime is very different from a Kerr/ de Sitter one. They have something common.
Call it black hole, or whatever you want ! It doesn't matter at all.
The exact GR solutions are there, and that's all we need!
There are also even more weird cases with planar black holes, or( in d>4) black rings and more...
Certain conditions are also necessary for the definition of mass in GR. Does that mean that one cannot have a definition for mass in Schwarzschild/dS, for example? I don't see why one can't use different definitions for each case.
Of course there are some philosophers that are bothered much about strict definitions, but GR has a very rich structure to be confined to our intuitions about simplicity and rigour.
A Kerr black hole with a/m= 0.99999 is totally different from one that has exactly a/m= 1. Does it really matter how you call the extremal horizon?
Is it a "degenerate", or a Cauchy horizon? Who cares?
About the case of a collapsing FLRW universe:
A physically realistic collapsing universe is a huge mess, and that's exactly what R. Penrose stresses in many of his lectures about cosmology:
Due to unavoidable inhomogeneities (one needs extreme fine tuning for an idealised homogeneous collapse), the final stages of the collapsing phase are, actually, a coalescence of huge supermassive black holes (yes, I call them black holes without problem. You can call them apparent (or whatever) black holes, if you like.).
Penrose shows how different a realistic time reversed version of an expanding universe actually is, compared with the naive expectations, due to the 2nd law of thermodynamics (but that's a different story).
This is actually old news: Everybody that attended one of his cosmology lectures remembers his arguments (and his characteristic drawings).
It is if you are claiming that the holes share one singularity. That's not true if they never merge. Just having it be "possible" that they will merge is not enough. They have to actually merge some time in the future.
In this thread, we are using the standard GR definition that I gave (but see further comments below for a clarification). If you want to talk about other kinds of spacetime geometric phenomena, please start a new thread.
For Kerr-de Sitter spacetime, the black hole definition I gave is easily generalized so that the cosmological horizon plays the role of future null infinity; i.e., the event horizon in this spacetime is the boundary of the region that cannot send light signals to the cosmological horizon.
I have not seen a similar generalization made for Kerr-Anti de Sitter spacetime, but I suppose one could be made.
In all of these cases, there is still an event horizon, bounding some region from which light signals cannot escape, and a singularity inside it. So if you want to treat that as the generalized definition of a "black hole" for this thread, that's fine. It still doesn't include cases like closed FRW universes. So once again, if you want to talk about cases other than the ones that fall into the general category I just described, please start a new thread.
Yes, Penrose shows how we would expect a closed FRW universe that recollapses to recollapse to a "Big Crunch" in which the Weyl tensor increases without bound, whereas in the initial "Big Bang", the Weyl tensor vanishes. That doesn't change the fact that there are no event horizons in a closed collapsing FRW universe. So, once again, it doesn't fall into the "black hole" category that we are discussing in this thread. So if you want to talk about it, please start a new thread.
Once again:
The point that I've made with the supermassive black hole coalescence is that, according to the typical definition that you're using, these cannot be considered "Different" black holes in the case that they will merge in the future, and I already told you, more than once, that, typically, I agree! Call them what you like.
That does not change anything, not in this case, neither in the case of a galaxy that's collapsing inside its Schwarzschild radius or in the case of a closed universe!
General Relativity gives as an accurate (as far as we know) description of what's happening in all these cases and that's sufficient enough.
Actually, if I wanted to argue about just words , I could start a thread in some other kind of forum.
That's not my intention.
Concerning R. Penrose's lectures: So, if you're aware of them, why did you ask for references?
I'm sure, also, that you certainly remember that he called them black holes! (Heresy!).
  • Skeptical
You have already been corrected more than once about your claims regarding a closed universe. A closed universe simply does not work the same as any of the other examples we have discussed.
I asked you for references regarding your claims, not Penrose's. His claims are not the same as yours.
He did use the term, yes. But not with any of the definitions I have said are on topic in this thread. And as I've already told you more than once, if you want to discuss other definitions, you need to start a separate thread.
Enough is enough. You are now banned from further posting in this thread.
PeterDonis said:
No. The definition of a black hole is a region of spacetime that cannot send light signals to infinity. Once you are inside such a region, you're inside it. The idea of having a second such region inside the first doesn't even make sense.
I would like to find a way to ask about the original intent of the thread in a hopefully meaningful way. I think it is an interesting question.
Let us say we have a definition of BH for cosmological spacetimes (FLRW in the continuous limit, but this is clearly an approximation). There are clearly things we treat as BH in a universe that is only approximately FLRW.
Then, imagine that in some region, by quirk of ejection from galaxies, or just wildly improbable initial conditions, we have a region of spacetime with 42 BH with minimal mutual relative motion. Over time, they will coalesce. In their initial state, each has a separate, observable, near horizon region that produces characteristic optical distortions of the distant stars. For all practical purposes, there are 42 separate horizons, of observable angular size for some moderately distant observer.
As they coalesce, long before their initially observed horizons would be expected to meet, they are collectively within the Schwarzschild radius associated with their aggregate distantly measured mass (e.g. by orbits of test bodies around the cluster of BH). By the hoop conjecture, they must now all be within the event horizon of aggregate BH. To the distant observer, they all will have effectively vanished, and only a giant ultrablack region will be 'seen'. Yet, internally, the quasilocal physics around each BH cannot have radically changed.
What to call the state after the supermassive horizon has formed, but each formerly separate BH is still expected to be many millions of kilometers from is neighbors? Physically, it seems 42 BH within a large BH is the most natural description, even if this doesn't fit the formal mathematical definition.
Just for clarification, would an observer far away recognize the formation of the supermassiv horizon as a sudden event by observing the stars behind the BH cluster?
Fast, but not sudden. I believe the cluster would be observed to rapidly blacken, with more and more extreme optical distortion around near its outer region. Quickly, it would be spherical black region with extreme optical distortion around its edge. This follows from the "no hair theorem" for BH.
The only really workable definition for spacetimes that do not have a future null infinity, such as FLRW, is that a "black hole" is a region bounded by an apparent horizon. Since apparent horizons are frame-dependent, this definition has significant limitations, but there simply is no invariant that we can use to define a "black hole" in these spacetimes.
With the "apparent horizon" definition, as I believe I mentioned much earlier in this thread, it is possible to have a "black hole" inside another "black hole"--i.e., an apparent horizon, a region inside it, and then another apparent horizon inside that region--but it requires fairly exotic conditions (for example, I believe violations of energy conditions are required).
The hoop conjecture doesn't apply to spacetimes with no future null infinity--at least not in the "event horizon" form that you have stated here. There might be another similar conjecture that involves apparent horizons, but I'm not aware of one.
Note that this can happen with an apparent horizon: outgoing light at an apparent horizon no longer moves outward locally, so it is "stuck" there, and can remain "stuck" there for very long periods of time, so to distant observers, it looks the same as an event horizon would look (if an event horizon were possible in their spacetime). So from observational evidence alone we cannot infer the presence of event horizons. This should not be surprising since the event horizon is teleological--where it is depends, not just on the local physics, but on the entire global future of the spacetime. And of course we can't know that.
The "no hair" theorem also does not apply in spacetimes with no future null infinity and therefore no event horizons. When stated properly, the "no hair" theorem is just the fact that the Kerr-Newman family of spacetime geometries contains all possible black holes, where "black hole" is defined using the standard "event horizon" definition that requires the presence of a future null infinity. There is no "no hair" theorem that I'm aware of for any other family of spacetimes, including FRW spacetimes with apparent horizons in them.
From far away, the formation of an apparent horizon around the entire cluster would look much as @PAllen described, but not for the reason he gave (the "no hair" theorem), since, as I pointed out just now, that theorem doesn't apply in spacetimes that don't have a future null infinity. The correct way to analyze such a case (although it would require numerical simulation for anything quantitative) would be to analyze the implications of an apparent horizon forming around the entire cluster, with the individual apparent horizons of each individual BH inside it.
Note that in my example, there is no matter at all, just evolution of Weyl curvature. Clearly no energy condition violations. Of course, the situation is implausible for other reasons.
If that's all that's present, I don't think it's possible to have one apparent horizon inside another; I think all you can get with pure Weyl curvature is one apparent horizon (possibly with multiple "legs" that merge as multiple individual objects coalesce). I think you need a nonzero stress-energy tensor that violates energy conditions to get multiple apparent horizons inside one big one.
That doesn’t make sense for my scenario. All the apparent horizon BH can be old, with no matter inside. There is no plausible way for them to coalesce without producing a boundIng apparent horizon containing the original ones, way before any mergers. You can take my scenario as taking place in asymptotically flat spacetime. Then the hoop conjecture and no hair theorem do apply.
Then I don't think your scenario is possible if it involves multiple small apparent horizons inside one big one, with no matter anywhere.
In an asymptotically flat spacetime, the event horizon for the case you describe would be outside the apparent horizon, and would be a single surface in spacetime with multiple "legs" to the past and one big region to the future. There would still not be multiple apparent horizons inside one big one; there might be an apparent horizon with multiple "legs" (similar to the overall shape of the event horizon), but it would be inside the event horizon, as I noted just now.
Yes, but all they say then is that there would be an event horizon with the shape I described above.
Bear in mind that, unlike event horizons (which are always null surfaces), apparent horizons can be spacelike surfaces (or timelike, but that case doesn't concern us here--it comes into play in cases like black hole evaporation by Hawking radiation). Heuristically, in a coalescence such as you describe, at the point where, according to your description, all of the mass of the cluster is just inside the Schwarzschild radius corresponding to that mass, the apparent horizons would all "jump" outward along spacelike surfaces to become one big apparent horizon. You would not have multiple small apparent horizons inside one big one.
