Can MCNP solve the geometric coincidence issue with a semi-cylinder and cuboid?
The discussion revolves around the geometric coincidence issue encountered when modeling a semi-cylinder within a cuboid using MCNP (Monte Carlo N-Particle Transport Code). Participants explore the challenges of defining shapes and their intersections in the context of Constructive Solid Geometry.
  • One participant raises a question about solving the geometric coincidence problem when fitting a semi-cylinder into a cuboid, indicating it is geometrically problematic.
  • Another participant mentions that MCNP uses Constructive Solid Geometry, suggesting that shapes should intersect and that the user must specify which volumes correspond to different parts of the problem.
  • A participant describes an issue where only two out of four cubes are displayed, questioning why the expected cuboids are not visible in the model.
  • Discussion includes a technical clarification about cell definitions, where positive surfaces indicate areas above or outside, while negative surfaces indicate below or inside, with a specific example provided regarding cell definitions.
  • One participant acknowledges a mistake in the X-axis orientation affecting the surface definitions, indicating a correction was made.
  • Despite correcting the X-axis error, another participant notes that a modeling problem persists in cell card 1, questioning why cell card 1 and cell card 2 are defined similarly when only one causes an issue.
  • A participant observes that MCNP appears to function correctly, while a tool called VisEd does not seem to display the model as expected, suggesting that VisEd may have issues with comments in the model.
The discussion contains multiple competing views and unresolved issues regarding the geometric modeling in MCNP, with participants expressing differing experiences and interpretations of the software's behavior.
Participants express uncertainty about the correct definitions and configurations of surfaces and cells, indicating potential limitations in their understanding of the software's requirements for geometric modeling.
chengmo
How do we solve the geometric coincidence problem? I need a semi-cylinder that fits into the cuboid but if I use the cuboid and the cylinder directly it's geometrically problematic
I'm not quite following the question. MCNP does Constructive Solid Geometry. Shapes are supposed to intersect and then you tell it which volumes are what part of the problem.
I set up four cubes but only two are displayed. In my setting, there should be cuboids in the middle and under the ring. Why?
In a cell definition a positive surface typically means above or outside. A negative surface means below or inside. If you take a look at cell 3, you have -3 4, meaning below x=4 and at the same time above x=6. The space between x=4 and 6 is "3 -4". Now have a look at cell 4 and see if you can find something similar.
Thank you very much Alex A, I got the X-axis wrong. The sign of 1, 2,3, and 4 surfaces in the surface card is wrong
However, after I corrected the error of x axis, the modeling problem still occurred in cell card 1. Why is cell card 2 and cell card 1 written in the same way? cell1 caused the problem, but cell2 did not
  • A1++.txt
    A1++.txt
MCNP seems happy. When I try the interactive plotter I see the full D. VisEd does not seem happy from your picture. Maybe VisEd does not like the comment. I do not see an error.
  • · Replies 17 ·
