Can Non-Separable ODEs Be Solved with Coordinate Transformations?
  • Level: Undergrad
  • Thread starter Thread starter jk22
    Ode Separable
13 replies · 4K views · last reply
jk22
I fell upon such an equation :
$$-E'(v)a(1+\frac{cE(v)}{\sqrt{E(v)^2-1}})=vE(v)+c\sqrt{E(v)^2-1}$$
It's not separable in E on one side and v expression on the other.
So I'm looking for methods to solve this maybe changes of coordinates ?
Assuming E(v) is positive we can transform it to
[tex]-FdE=dv[/tex]
where
[tex]F=\frac{a(1+\frac{c}{\sqrt{1-E^{-2}}})}{E(v+c\sqrt{1-E^{-2}})}[/tex]
Ah, you are right.
Then I try
[tex]E=\coth w[/tex] and get
[tex]a(\sinh w +c\cosh w)\frac{dw}{dv}+v\cosh w+c\sinh w=0[/tex]
It is not separable yet.
E should be dimensionless. Are a,c and v are also dimensionless parameters? If not I am afraid there is something wrong in your equation.
You're right this equation is wrong. I'll look at the calculation again.
jk22 said:
It shall read :
$$-E'(v)*t*a(v+\frac{cE(v)}{\sqrt{E(v)^2-1}})=vE(v)+c\sqrt{E(v)^2-1}$$
But it anyhow is wrong since there shall be derivatives towards v and t.
Thanks for your help.
If you explain physical meanings of E, v, a, t ,c and v, I would be able to consider more to help you.
E is supposed to be an analog to the gamma factor, t time, a acceleration, c speed of light and v speed.
But the derivation of the equation is wrong. I wrote a coordinate transformation ##x'=A(v,t)x+B(v,t)t##, ##t'=D(v,t)x+E(v,t)t##
The equations are ##c^2t'^2-x'^2=c^2t^2-x^2## and ##\frac{dx'}{dt'}|_{x=0}=-v##
A mistake I made came while computing ##dx'## only with a partial derivative towards ##v##.
[tex]x'=Ax+Bct[/tex]
[tex]ct'=Dx+Ect[/tex]
[tex]c^2t'^2-x'^2=(E^2-B^2)c^2t^2-(A^2-D^2)x^2+2(DE-AB)xct[/tex]
So
[tex]E=\cosh \phi[/tex]
[tex]B=\sinh \phi[/tex]
[tex]A=\cosh \psi[/tex]
[tex]D= \sinh \psi[/tex]
[tex]\frac{x'}{ct'}|_{x=0}=\frac{B}{E}=-\frac{v}{c}[/tex]
[tex]\frac{x}{ct}|_{x'=0}=-\frac{D}{A}=\frac{v}{c}[/tex]
So
[tex]\phi = \psi[/tex]
[tex]\tanh\phi=-\frac{v}{c}[/tex]
[tex]E=A= \cosh \phi=\frac{1}{\sqrt{1-v^2/c^2}}[/tex]
[tex]B=D= \sinh \phi=\frac{-v/c}{\sqrt{1-v^2/c^2}}[/tex]
Nice, I took a wrong start with writing dependencies of ##A,B,D,E## wrt v and t and then taking the differential ##dx'##, making the equations unsolvable.
The question is explained so vaguely that it's impossible to tell whether a is a function or a constant.
But is it a problem that A is a function of v but v is a constant. So when we plot A(v), v varies, but it varies in function of what ? Human free choice or it could be safe to say that the unknowns depends on the known or given variables ?
I think I got knotted in a circular reasoning :
If B(v), then allowing to change v (for any kind of ground) induces a dv/dt, then the hypothesis was wrong and in fact B(a,v), aso, such that the ODE is of infinite degree since ##B(\{\frac{d^n v}{dt^n}\}_{n=0}^\infty)##
