I Can resonance be used to split a molecule of CO2?
Sveral
Hello,
interested, if the posibility of splitting atoms by using resonance is possible, if so, wheather or not I can use it for something else, thanks in advance.
You mean to dissociate a molecule?
If so, what resonance are you thinking about?
Yes, exactly. I`m thinking about the dissociation of the nucleus of, for example, CO2 into Carbon and oxygen. Hope it makes sense
You haven't said what resonance you are thinking about.
You mean, how I intend to create the resonance itself? Sound, very high frequency.
You can't use sound to break a molecule like CO2.
If the input frequency matches the frequency of self-oscillation of the bond between C and O, then, why not? Any ideas as to, where to find the frequencies of bonds between certain elements or how to calculate them?
Even if you could do that in theory, molecular vibrations are highly non-linear, so there isn't a single frequency you could excite at. And the link you gave talks about using laser light, which is not the same thing! Even then, simply vibrationally exciting a molecule at a single frequency won't work, but time-varying frequencies are needed.
At the molecular level, a sound wave simply corresponds to collisions between molecules. Regular chemistry applies.
There are several reasons. One is that frequencies involved in molecules are optical, i.e. a few THz at the very least. "Sound" in the usual sense of the word only goes up to a few MHz at most (for ultrasound). Note also that this neglects the (not so small) problem of how you would "convert" your (theoretical) sound into the energy needed to actually break the bond.
Also, just think of the wavelength of sound compared to the size of the molecule.
Note that both of the explanations above neglects a LOT of physics; I am merely trying to illustrate why it wouldn't work,
Likes DrClaude
That is a point even one with my...knowledge can understand, well put.
Ok, but what about the link I posted? It should mean, that it is doable with light...
Much appreciated for the information. Thank you.
DrClaude said:
It is done all the time with light. People have been working for decades now on breaking specific bonds in molecules.
Ok, but any ideas as to how to calculate the resonant frequency of a bond of C-O? Also are there any DIY verions of wideband light generation chips or something?
The easiest is to look at the infrared spectrum http://webbook.nist.gov/cgi/cbook.cgi?ID=C124389&Type=IR-SPEC&Index=1
I don't think that the equipment needed to do this is within reach of a layman.
Likes Sveral
Any ideas as to, how one can calculate the output frequency of a laser diode by knowing the type of semiconductors used?
easier to measure it by observing the color of the laser light. Or more quantitatively, measuring the distance between fringes in an interference pattern
Solid answer, but seems like I need to specify the question. If I know everything about every component that`ll be used for the building of the laser, how can I calculate the frequency using those numbers?
Buy a laser where they tell you the frequency on the box. I think the calculations you want to do are very complex. But there may be simpler method that I've missed.
You can't. The laser frequency will depend on the details of the device design and the choice of material is only one of several factors. Laser diodes are complex devices built up of many semiconductor layers with different composition; there are also many different ways to make a laser diode (a InGaAs based VCSEL is very different from the "classical" red Si based diode).
Hence, you need to either measure it or just read the datasheet.
A. K. A. It's far from simple or DIY...
Nino MMP said:
You might enjoy looking up the HCl canon. It's a physical chemistry experiment with H2 and Cl2 in a container; it demonstres how a certain wavelength is needed to break a bond of diatomic chloride, forming HCl and a 'canon' effect.
I would like to point out that in this case, the molecule dissociates due to electronic excitation, not vibrational excitation.
Likes Nino MMP
Nino MMP said:
Oh okay, thank you for the correction DrClaude! Would atomic/optical books be best to read into this more? I am intrigued.
This will be covered in some books on atomic and molecular physics, but it is getting closer to chemistry than to physics.
Likes Nino MMP
E=h (nu) where nu is frequency and nu or sometimes f=v/lambda where v here would be the speed of light. Play with these and the energy of a CO2 bond (typically in kJ/mol - there's tables for it anywhere from google). That paired with the typical wavelength for sound help explain why that wouldn't really work. There are plenty of E/M wavelengths that will break the bond in question, though.
Ok, will do, thanks.
Likes Nino MMP
May be too late to reply but as I recall to reach the first dissociation limit of CO2 to become CO and O, you need around 7.5 eV photon energy. You will need laser in the UV range to do this dissociation.
Likes Nino MMP
Actually useful, not too late.
Nino MMP said:
Ah okay great! Yep, unfortunately my passion seems to repeatedly be right at the interface of the physical sciences. Thank you, sir.
I looked for the HCl cannon, but couldn`t seem to find it. Any chance you could toss in a link?
Does anyone know of a good website , where one can nuclear magnetic resonance frequencies of aromatics and alkanes? (
toluene, m,p-xylene, 1,3,5-trimethylbenzene, benzene, and propene)
  • #31
  • #32
Could you us the Kuramoto model to synchronise the atoms first before applying a dissonant frequency?
  • #33
Could you apply the Kuramoto model to synchronise the atoms before applying a dissonant frequency?
  • #34
Thread closed temporarily for Moderation after necropost...
  • #35
Thread will remain closed.
@Biskityas -- If you want to discuss this, please start a new thread and post links to the technical reading you've been doing about this. Thank you.
