- 35,014
- 21,725
Will SMR's (Small Modular Reactors) allow for nuclear powered surface combatants to make a comeback?
The US Navy used to operate a fleet of nuclear powered cruisers in addition to aircraft carriers and submarines. Most were based on the General Electric D2G reactor, which is around 30x30x40 (height) feet in size and delivered 50 MW or so.
These were all decommissioned in the 90's for a number of reasons:
Reactor + fuel cost is comparable to conventional fuel cost, per year of operations. But, you don;t have to worry about supply lines to get your fuel to your ship. Every few years you refuel -- at home.
Is there some reason they haven't jumped on this?
- Refueling was length and expensive - the reactors were so large you needed to cut a big hole in the ship to get where you needed to go.
- The crew that operated these reactors needed to be highly trained. Costs are comparable to training a pilot. You also needed trained crew to handle activities that were important but not directly part of running the reactor, like reactor chemistry.
- The power quantization is coarse - if you need 1.1 reactors, you need to have 2. That makes them expensive.
- Gas turbine technology replaced steam; this takes fewer people to operate, in no small part because if something breaks, you can't easily fix it - so reliability must go up.
- They are smaller and easier to replace
- They require very little in the way of operators - in many ways they are more like a battery than a reactor.
- Granularity is finer, although the eVinci's 5 MW probably takes it too far.
