Why Does the Cord Break at 200 N Tension in the Elevator Problem?
  • Thread starter Thread starter Gauss177
    Explain
The discussion centers on a physics problem involving a monkey hanging from a cord in an accelerating elevator. The cord can withstand a maximum tension of 200 N, and the calculations show that the minimum acceleration of the elevator, which would cause the cord to break, is 3.53 m/s². The tension in the cord is calculated by balancing the forces acting on the monkey, leading to the conclusion that if the elevator accelerates beyond this threshold, the cord will break. The key point is that while 3.53 m/s² is the exact acceleration at which the cord remains intact, any acceleration greater than this will result in the cord breaking. Thus, the minimum acceleration required for the cord to break is established as being slightly above 3.53 m/s².
Gauss177
A 15.0-kg monkey hangs from a cord suspended from the ceiling of an elevator. The cord can withstand a tension of 200 N and breaks as the elevator accelerates. What was the elevator's minimum acceleration (magnitude and direction)?
I labeled the force of rope as Fr, so:
Fr - mg = ma
(200 N) - (15.0 kg)(9.8 m/s^2) = (15.0 kg)a
a = 3.53 m/s^2
This is the answer I came to. My question is why is 200 N plugged into the equation above? I don't see any other way to do it, but the problem states that the cord can withstand a tension of 200 N, so if I plug in 200 N the cord still wouldn't break? But then again I don't see how else to do it.
Another way of looking at this question is find the maximum acceleration of the elevator if the maximum tension the cord can withstand is 200N. If the elevator accelerated at a greater rate the cord would break. However, we know that the cord did break, therefore we can say that for the chord to break the inequality a>3.53 must be true. You however, are quite correct, if the elevator accelerated at exactly 3.53m/s2, then the cord would not break. If the acceleration was only slightly greater than this value then it would break. Therefore, this value of acceleration is said to be the minimum value at which the cord will break.
I hope that makes sense.
  • · Replies 25 ·
10K
  • · Replies 33 ·
