Can something massless be stationary ?
  • Level: Graduate
  • Thread starter Thread starter ValenceE
    Massless
26 replies · 6K views
ValenceE
Hello to all,
something came up in another forum and I would like to ask the following question ;
In outer space, or anywhere outside a confined physics experiment, can something massless be stationary ?
Regards,
VE
Ask the question in reverse. What makes a particle stationary? If it has no mass, but charge for instance, would it not move immediately without let or hinderance towards the nearest opposite charge?
While mass, and hence gravity, might well be appear to be cincure for defining motion, forgeting charge and spin as potential causal agents for motion would be short sighted.
ValenceE said:
Hello to all,
Regards,
VE
No.....
clem said:
No.....
What if it's the only thing in the universe and it's massless? How would you know if it was moving or not without anything to compare it to? Couldn't it be said to be stationary? If a photon moves by definition, then can it be said that a photon can't exist without something else existing to compare it's speed to?
If it is the only thing in the universe, then why would you care if it moves or not? There's nothing else to determine what it is doing. The "you" in your scenario already contradicts your premise of it being the only thing in the universe.
Zz.
Velocity is strictly relative. You cannot simply say "the object is at rest," because that is not meaningful. You must instead say, "the object is at rest with respect to me."
In this sense, any object -- with or without mass or charge -- can be at rest with respect to any other object.
- Warren
Pure curiosity.
Zz.
Sure, but I'm pretending I'm an ethereal goddish figure in this case. Do I have to be in that universe also in order to conceive of the idea?
Motion is only defined relative to other objects. So if something is the only object it cannot have motion. But a photon by definition must move. In a universe with only one photon, the photon must move at c, but yet also cannot move. It's a paradox. So how can it exist in this situation? Wouldn't you have to redefine movement or redefine a photon to get it to exist by itself (or add another particle to measure against)? You don't have to do that with a particle that doesn't have a set speed. Doesn't this suggest that somethng very odd is going on with light - as if we didn't already know?
- Warren
A photon can be at rest with respect to some other object? I would say no.
Well, you have a point -- anything without mass necessarily moves at c. I don't actually know the pedantic answer for whether two photons traveling in the same direction can be said to be at rest with one another.
- Warren
Meatbot said:
Pure curiosity.
Then I can also be a goddish figure (after all, if you can, so can I) and tell you that it makes no sense to define something that only exists in that universe. After all, if we're making things up and setting up our own rules, my rules should work as well.
This then shows that this made-up scenario is meaningless and proves nothing.
Zz.
What about two photons traveling parallel to each other (previously mentioned)? I think this demands an answer. We can't just dismiss this as an irrelevant oddity. Something has to give here. We have to postulate an odd solution. Perhaps they CAN be stationary relative to something else. Perhaps there is no "other" photon and all photons are one so the question is moot. Perhaps we have a mistaken notion of what motion is all about. Perhaps photons can't travel parallel to each other. Perhaps photons don't even move in the first place. Perhaps the photons ARE moving apart at c, but the space between them is shrinking at c. Perhaps they are moving apart at c in another dimension. Perhaps there are actually no photons. I don't know. I can come up with lots of other bizarre things like this that are probably way off the mark - but maybe not. It's time to think outside the box on this one. Let's not avoid the issue.
I'll accept that it proves nothing, but it's certainly not meaningless to ask about. It's an important thought experiment. At the very least it makes you think and that's a positive thing. Are you saying nothing can be gained from imagining bizarre situations?
I know it's fun to make up stuff and ask off-the-wall questions, but give us a break with the melodrama.
Two photons moving side by side will of course both move with respect to any local reference frame at speed c. As far as what the speed of one photon is with respect to the other, that question has no meaningful answer as one cannot define a reference frame for a photon.
Note that if the photons are moving towards (or away from) each other, there's no problem in saying that they are closing (or separating) at the rate of twice the speed of light--again, as measured with respect to some reference frame.
Meatbot said:
Pure curiosity.
Is it possible to define motion, then as being relative to some arbitrary coordinate system? Nothing else would technically have to exist in the physical sense for such a quantity to be calculated in this case, I don't think.
The most important aspect about a thought experiment is that it must be grounded in something that is a possibility under an ideal situation! Yours is neither grounded, nor a possibility. It serves no purpose.
Zz.
Zz.
I'm unsure as to how someone can define a thought experiment's purpose other than in a subjective manner. One could argue that the entire purpose of a thought experiment is just... to think... no?
1. How do you know that's not a possibility? 2. Why does it have to be possible to get something useful out of thinking about it?
Perhaps - but irrelevant.
I would respectfully disagree there. It makes you think. It makes you consider things you might not have considered before. It makes you ask yourself why it's not possible. Plus, in order for you to say it's not possible, you would need to either explain how the laws of physics forbid it or explain how it's logically self-contradictory. That explanation would be illuminating.
Why not? Isn't the photon at rest with regard to a parallel one? Why isn't that an inertial reference frame? Why do you have to define it relative to a non-photon for it to make sense? I'm sure I just don't understand relativity well enough. I'm just trying to learn.
How do you "explain" something when the premise doesn't allow you to make any "frame" for you to based any explanation on?
You are forgetting that the ability to "explain" something requres an a priori agreement of the rules that everyone agrees on. Here, it is physics. When you set up your scenario, have you considered what physics have you disallowed? There's nothing to detect this photon in a solitary universe. Your question itself is "logically self-contradictory". How come that realization isn't "illuminating" in itself?
Zz.
Exactly.
? What does it mean? For relativistic speeds, you can't use V = v1 + v2 (or V = v1 - v2);
you should use V = (v1 + v2)/(1 + v1v2/c^2) and, however, you can't use even that one in the case of two photons.
Reread what I wrote. Example: In the lab frame I observe photon A moving to the right towards photon B which moves to the left. At some time (according to the lab frame), each photon is one light year away from me, thus 2 light years apart. When do they reach me? In one year. Thus they covered a distance of 2 light years in one year.
I generally refer to this as the third-party separation rate, since it is the separation rate of two objects with respect to a third (not each other). Not to be confused with the speed of one photon with respect to the other.
Photons are massless and move at c. So, the photon is at rest with respect to itself isn't it? But the photon doesn't experience time or space because it's traveling at c.
Ok, however you should probably have specified that you weren't talking about the "common" definition of speed but about another one; not much for me but for people who still haven't understood that you can't travel faster than c. :smile:
No. To say that, you should find a ref. frame stationary with respect to the photon and you can't find it.
See up.
See up.
If you assume that the reference frame is the photon itself (or some point at the center of the photon, I suppose), I don't see how anyone could claim that the photon isn't at rest relative to itself. By definition, the reference frame would move as the photon moves, essentially defining the state of being stationary, wouldn't it?
Yes but the problem here is the physical concept "ref frame", which is much more than what one simplicistically could believe. To have such a thing, it's not enough to simply draw coordinates with respect to the photon (or the object considered, in general): you have to show that you could put clocks in every point of space co-moving with that object; you understand that it's physically impossible for photons.
Physics is different from mathematics. :smile:
Edit: all this without considering the fact that we don't even know where the photon exactly is in space, between two detections.
Ah, I believe I'm beginning to see it now. I don't have any professional training in physics or mathematics yet; I'm still trying to grasp where one starts and the other begins. :smile:
If there is simply one thing in the universe, your photon. Then the only way to measure its velocity would be from the reference point of the photon. Which makes it undefined.
