Can the Cesaro Mean Be Zero Even if the Sequence Diverges?
  • Thread starter Thread starter mlarson9000
    Mean
The discussion revolves around the Cesaro mean and its behavior in relation to a sequence that diverges. The original poster questions whether it is possible for the Cesaro mean to approach zero while the sequence itself remains positive and diverges to infinity.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the construction of sequences that could demonstrate the behavior of the Cesaro mean. There are discussions about piecewise sequences and the implications of subsequences diverging to infinity while keeping the Cesaro mean small.
Several participants have proposed potential sequences and are engaged in verifying their validity. There is an ongoing exploration of how to formally prove the behavior of the Cesaro mean in relation to the constructed sequences. While some guidance has been offered, there is no explicit consensus on a definitive approach yet.
Participants are considering constraints such as the requirement for the sequence to consist of positive numbers and the implications of the Cesaro mean approaching zero despite the sequence diverging. There is also mention of specific values and limits that need to be addressed in the context of the problem.
mlarson9000
Define the cesaro mean as σ=(1/n)(x1 +...+xn)
Can it happen that xn >0 for all n, and limsup xn =∞, but limσ=0
I think I am supposed to construct a piecewise sequence, with ln(n), but I can't figure this out or the life of me. The professor says there is a sequence that will work.
So [itex]\limsup x_n = +\infty[/itex] means that there is a subsequence that diverges to infinity.
So we know that there must be a subsequence that becomes arbitrarily large. However, if the other terms of the sequence are small and if the elements of the subsequence lie very far apart, then you can see that you can make the Cesaro mean small.
If you don't see how to do it immediately. Can you come up with 100 positive numbers such that the largest number is greater or equal than 10, but such that the mean is smaller than 0.5 ??
Now, can you add 1000 numbers to that sequence such that the largest number is greater than 20, but such that the mean is smaller than 0.05 ??
Can you generalize this idea?
I have a piecewise sequence for xn, where xn = √n for x10n , 1/n2 otherwise.
I know that the series 1/n2 converges, so that part of the mean will go to zero when it is divided by n.
For the other part, √n:
at n=10, xn/n=.31
at n=100, xn/n=.1
at n=1000, xn/n=.031
I think that will work, I'm just not sure how to say this in the form of a proof.
"It looks like the mean will get very small," doesn't seem very rigourous.
Am I on the right track at least?
I don't see why you are calculating [itex]\frac{x_n}{n}[/itex]. That's not the Cesaro mean...
What I have for the sequence I described is:
σ10=.599
σ100=.101
σ1000=.032
But I'm not sure how to describe this formally.
Try defining ##x_n## such that the subsequence where ##n = 2^k## (i.e. powers of 2) increases to infinity at a suitably slow pace. Then make ##x_n## small and decreasing toward 0 for all other values of ##n##.
I think we have found a couple that will work, the difficult part is proving it. How do I do that?
Well, that depends on what sequence you have chosen. But to speak in general terms, let's say we define ##a_n## to be any sequence of positive numbers such that ##\sum_{n=1}^{\infty} a_n = L## is finite. Then define ##b_n## to be zero whenever ##n## is not a power of 2. For ##n## equal to a power of 2, use something that grows slowly to infinity. Then put ##x_n = a_n + b_n##. We have
$$\begin{align}
\frac{1}{N}\sum_{n=1}^{N} x_n &= \frac{1}{N}\sum_{n=1}^{N} a_n + \frac{1}{N}\sum_{n=1}^{N} b_n \\
&\leq \frac{1}{N}\sum_{n=1}^{\infty} a_n + \frac{1}{N}\sum_{n=1}^{N} b_n \\
&= \frac{L}{N} + \frac{1}{N}\sum_{n=1}^{N} b_n \\
&= \frac{L}{N} + \frac{1}{N}\sum_{n\textrm{ a power of 2}} b_n \\
\end{align}$$
What happens next depends on how you chose ##b_n##. So what do you propose to use for ##b_n##?
I have an=1/(10n), for n≠10k
bn=log(n) if n=10k
I think the argument should go as follows. Since b10 =1, b100=2, b1000= 3, etc., then,
σn≤(1/n)[Ʃ10-n] +n*10-n
Taking the limit of that as n→∞ would be zero. Does that make sense?
bn=log(n) if n=10k
Yes, this will work. For the second sum, you can write
$$\begin{align}
&= \frac{1}{N}\left(\sum_{n \leq N, n \textrm{ a power of 10}} \log_{10}(n)\right) \\
&= \frac{1}{N} \sum_{k = 1}^{\lfloor \log_{10}(N) \rfloor} k \\
&= \frac{1}{N} \frac{(\lfloor \log_{10}(N)\rfloor)(\lfloor\log_{10}(N)\rfloor+1)}{2} \\
\end{align}$$
where ##\lfloor \cdot \rfloor## denotes the floor function. You should be able to argue pretty easily that this converges to ##0## as ##N \rightarrow \infty##.
Thank you!
