Can the Movement of Atomic Parts Be Measured in Time?
  • Thread starter Thread starter 0day
    Atoms States
The discussion revolves around measuring time delays in the movement of atomic parts, specifically protons and neutrons versus electrons. It clarifies that electrons do not move in a classical sense within atoms, as their behavior is described by quantum mechanics. The concept of a "pool ball effect" is questioned, highlighting that atomic interactions are better modeled through harmonic oscillators rather than direct collisions. Additionally, protons and neutrons in the nucleus are not easily treated as separate entities, complicating the understanding of their movement. Overall, the complexities of atomic structure and behavior challenge straightforward interpretations of atomic movement and timing.
0day
Physics noob here. I was wondering, is there a way to measure time delay between the movement of one part of an atom from another? Is there any?
"Movement" of what part of an atom?
Zz.
I'm trying to get a better grasp on whether protons and neutrons moving are separate or the same in time.
This is a bit puzzling.
Typically, when one asks "states of atoms", these are the electronic states.
Asking about protons and neutrons are "nuclear states".
So now I'm confused to what exactly you are asking for.
Zz.
Well electrons move at a rate that is supposed to be limited to the speed of light, so for example if a unit consisting of 2 atoms is pushed by a force, it would resemble a pool ball effect correct? But is this same effect true for neutrons and protons? Specifically is there a pool ball effect on protons and neutrons, or are they effectively linked in time?
There are several puzzling issues here:
1. Electrons in atoms/molecules don't actually "move". The quantum description of their states do not have such a description (also see the FAQ subforum on why electrons in an atom don't crash into the nucleus).
2. I'm not sure what you mean by the poll ball effect. Are you thinking of two things colliding physically? In a solid, the simplified model of the atoms arrangement is via linking them with "springs", or as an arrangement of harmonic oscillators. This is how action, or force, is transmitted. The valence electrons are the ones involved in connecting one atom to another. The nucleons are not involved at all in all of this fun, other than collectively undergoing the translation.
3. The activity going on in the nucleus isn't as easy as you think. Often, one can't think of the protons and neutrons being separate entities while they are in the nucleus (that's why often times they are called partons). I'm just not sure to what extent do you want the details.
Zz.
comparing a flat solar panel of area 2π r² and a hemisphere of the same area, the hemispherical solar panel would only occupy the area π r² of while the flat panel would occupy an entire 2π r² of land. wouldn't the hemispherical version have the same area of panel exposed to the sun, occupy less land space and can therefore increase the number of panels one land can have fitted? this would increase the power output proportionally as well. when I searched it up I wasn't satisfied with...
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
