Can the Plastic Moment be smaller than Elastic Moment?
1 reply · 3K views
CallumTheMan
Stress = 320 MPa
Max Elastic Moment = Stress*Z
Max Plastic Moment = Stress*S
Solve the maximum moments and compare the % increase
Beam is an I beam with dimensions: (b and d)
Top Flange = 25*10
web = 10*180
Bottom Flange = 200*8
see above
Ybar elastic = 63.3mm
Ybay plas = 30.5mm
Ix=1.687*10^7
Zx = 266501.107
S = 191868.75
S is lower than Zx and this makes the plastic M smaller than M elastic. How is that possible?
S= (25*10*162.5)+(10*157.5*67.5)+(22.5*10*11.25)+(200*8*26.5) this is the only value I had to manually generate without computer aid so there must be an error here?
Can't seem to find out what's going wrong.
CallumTheMan said:
Stress = 320 MPa
Top Flange = 25*10
web = 10*180
see above
Ybay plas = 30.5mm
Ix=1.687*10^7
Zx = 266501.107
S = 191868.75
You've actually got two errors here.
1. In the elastic regime, there are two section moduli for this beam, and you have calculated the greater SM of the two. Since this section is not symmetric about a horizontal axis, can you figure out the other SM for this beam?
2. In the calculation of the plastic SM, check the distance of the centroid of the upper web piece located above the plastic NA. I think there is a mistake here.
3. The location of the elastic NA, the plastic NA, and the MOI all check out.
